Go Back   6th Gen Accord DIY and Performance Forums > The Garage > DIY - Do It Yourself Forum
DIY - Do It Yourself Forum We have a lot of threads on how to do things yourself, from air intakes to suspension, brakes, even electronics. Please search first, if you can't find an article about what you're wanting to do just ask for help
Register to remove these ads
Reply
  #1
Old 02-07-2015, 01:05 AM
james'99 james'99 is offline
Senior Member
Points: 7,991, Level: 26 Points: 7,991, Level: 26 Points: 7,991, Level: 26
james'99 is more helpful than most
DIY: Manual Climate Control Repair (Electrical Failure)
If you are experiencing issues with your manual climate controls where the controls are not working and no matter what button you press, no lights light up (Defrost, low vents, high vents, recirc, etc.) and only the fan speed knob works, the common failure seems to be a broken connection in the PCB between 12v supply and the voltage regulator for the step down to 5V.
I covered this repair at a high level in this thread.
http://www.6thgenaccord.com/forums/s...highlight=HVAC
I found myself doing the repair on a second car so I decided it was time to share. This repair definitely applies to all 98-00 4 cylinder Accords with maybe the exception of DX Accords without A/C. It SHOULD apply to 98-02 Accord 4 cylinders with the minor exception I already stated and 98-02 Accord V6 LX editions with manual climate controls.
This takes a small amount of solder skill. Make sure you do the right wire run or you will find yourself having problems down the line.
I'd like to give credit where credit is due, but this original website seems to go up and down all the time but this is the original source from where I fixed my first one. I will now be doing a friend's.
http://petervieth.com/2012/01/29/hea...-honda-accord/
Obviously to protect myself...
NOT RESPONSIBLE FOR DAMAGE DONE TO YOUR CAR FROM THIS DIY. *SHOULD YOU DECIDE TO DISCONNECT THE BATTERY BEFORE PERFORMING THIS PROCEDURE, YOU WILL NEED RADIO CODE*
First, you will need to remove the climate controls from your dash. I don't have pictures at the current time but get a phillips head screwdriver, a common screwdriver (flat-head), and a paper towel. Cover the end of the common screwdriver (flat-head) with the paper towel and pry beneath the clock. It will pop out. Pull it away disconnecting the harness for the hazard switch and clock. You will find a screw hidden there.
Next, place the car in neutral if you need the room to work and get the two screws on the bottom. At this point, the climate controls will pull away.
Two harnesses to disconnect here. Green on the climate control board and brown on the fan control. Pull it away.
Now...
Turn it over. Twist out fan control light bulb. Remove seven gold screws gently. (Screw locations dotted in red.) If you aren't gentle, you will break these already brittle studs and you will find your buttons not actually pushing from the front without all the screws. The remedy without replacing the plastic simply put is duck tape across the back from the top to bottom of the plastic appending the white plastic to the black.
Pull plastic away gently and remove the board.
Now here is the wire I used. I have no idea what its called but it works great in this application. I has some kind of coating as its insulation. It is single strand. I'm hoping xci or someone else will tell me but we will see. Haha!
I scraped about a 1/16 in of the insulation off on each end. Depending on the path of your run, and the type of wire you use, you will need different lengths. For my thin wire, I think it's about 5-5.5 in. This picture doesn't show it well but it gives an idea.
Solder point to point!
These pictures are clearer from the first time I did it on my car.
Place the board back in the white housing and put on the black cover. Take extra care reinstalling the screws. I recommend placing them in the hole and turn them counterclockwise with the screwdriver till you feel the screw "fall in" slightly. This will decrease the possibility of the studs breaking and hopefully the screw will take the same exact path in that it took on the way out. Remember, this isn't like metal.
At this point, plug in and test. If you are all good! Great! If not, you may want to check the continuity between the two points which you soldered the wire between and check for voltage there if you plug it into the car and turn the key to on. If there is no voltage at one of the two points, there is an issue. There should be 12v at the point on the "left" that you soldered. You are repairing the path to the voltage regulator, the "right" one. When I say left and right, look at the first picture of the finished product titled, "Solder point to point!"
  #2
Old 02-20-2017, 02:25 PM
2000 2000 is offline
Junior Member
2000 is an unknown quantity at this point
Re: DIY: Manual Climate Control Repair (Electrical Failure)
Thank you James! My daughter and I just performed this fix on her 2000 Honda Accord EX (five speed) and it looks like it did the trick. The only thing that we noticed out of the ordinary is that the A/C light seems to flicker a bit.
  #3
Old 02-24-2017, 01:01 PM
dextv dextv is offline
Junior Member
Points: 52, Level: 1 Points: 52, Level: 1 Points: 52, Level: 1
dextv is an unknown quantity at this point
great instructions...i have a 2000 accord ex which was having problems changing vents and recirculating air... when i disassembled the unit, the solder points were smaller than i envisioned, but with a little persistence (and since i really didn't want to buy a new/used panel since i have kids to support), i got it done. thx
  #4
Old 02-26-2017, 04:48 PM
umop-apisdn umop-apisdn is offline
Points: 2,287, Level: 13 Points: 2,287, Level: 13 Points: 2,287, Level: 13
umop-apisdn is an unknown quantity at this point
I had to buy no less than three climate control units before I could get one to even begin to fix. The plastic housing likes to rub the PCB over time, severing traces along the way. PITA
  #5
Old 03-02-2017, 12:16 PM
Senior Member
I am glad this is helping more people out!
  #6
Old 03-20-2017, 11:44 AM
Connie Connie is offline
Senior Member
Points: 3,384, Level: 16 Points: 3,384, Level: 16 Points: 3,384, Level: 16
Connie is somewhat reliable
Cool write up; thankfully the only one I've have with this problem is my parts car, but nice to know what's wrong.
So much better than the solution I had in my old 92 Accord with the coat hanger in the passenger foot well; push for hot, pull for cold lol.
__________________
2002 Accord V6 Coupe, "Connie", 516,000km
2000 Accord V6 Coupe, "Midnight", 209,000km
2000 Accord V6 Coupe, 412,000km; 1998 Accord V6 Coupe, 266,000km; 1998 Accord V6 Sedan, 278,000km
  #7
Old 06-09-2017, 12:37 AM
NotNice NotNice is offline
Senior Member
Points: 11,955, Level: 33 Points: 11,955, Level: 33 Points: 11,955, Level: 33
Activity: 3% Activity: 3% Activity: 3%
NotNice is somewhat reliable
I am going to try this tomorrow morning. Would this issue cause the ac compressor to have no power as well? All the other symptoms is what I have plus no power to the compressor.
  #8
Old 06-09-2017, 01:00 PM
Senior Member
So answering my own question. Yes it cause the ac compressor to have no power. This fixed my issue and I have full power now.
Only thing off is only 2 of my vent options light up. They all work though once pushed
Thanks.
  #9
Old 12-15-2017, 11:24 AM
It's amazing how fragile these A/C controllers are. I've owned two 6 gens and both needed to be tinkered with multiple times.
I had one unit try to fry one of the brand new knob replacements. The underlying metal potentiometer was burning hot! Didn't even try to fix that one.
  #10
Old 12-18-2017, 05:12 PM
SupraGuy SupraGuy is offline
Senior Member
Points: 2,184, Level: 13 Points: 2,184, Level: 13 Points: 2,184, Level: 13
Activity: 1% Activity: 1% Activity: 1%
SupraGuy is somewhat reliable
I'm having exactly the issue described, and need to track down photos. Photobucket! Curse your sudden but inevitable betrayal!
__________________
1999 Honda Accord EX, 292,XXX kms, mostly stock.
1989 Toyota Supra, 502,XXX kms. Heavily modified, mostly dead.
1990 Toyota Supra, 190,XXX kms, project car.
Reply
Bookmarks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
» Featured Ride
