Within 5-10 minutes of driving regardless of speed, cruising usually the car will lose throttle response. The car won't turn off right away but if I'm at speed, I'll pull over and upon braking when I go slow enough the car will die. No engine codes. It won't restart right away, but if I wait a couple minutes it will start and usually it won't happen again.
I've done an engine swap from f23a1 to f23a and I believe it happened pre-swap as well. Kept all of the the hoses, sensors and transmission from original engine.
Things changed since: TPS, Cat, Cat o2 sensor and distributor
