cb1999nj
I have a 98 Accord LX 4 cyl.
I'm having a bit of headlight trouble. I have checked all bulbs high/low all new. Now the problem is as follows:
When I turn on my headlights the low beams work, but when I put the high beams on, they do not work, only the low beams. I get the interior blue high beam symbol. So I only have low beams. And also sometimes the low beam passenger will go out as well, but with a wiggle of the wire it goes back on. They are regular headlights, not halos.
Trying to figure out what could be the problem. Like I said, all new bulbs. I have checked for any loose wires and encountered none. Just give me an idea as to what to check and what to check for.
Also, are the headlights wiring harness and such connected with the engine wiring harness? If there is a short of some sort, would it be worth it to get a new engine harness if the headlight wiring harness is in fact apart of it? I can get one for 50 bucks.
Thanks.
Thanks.
