im trying to get the passenger axle out of the tranny but it will not come out. i used a pri-bar between the inner cv joint and tranny but no good. any suggestions on what i cud do?
i was thinkn that but i dont have one at home and i dont have a car to get to the parts store.
p.s i am using an angled pribar nd its a strong one.
also changed this axle 3 weeks ago and the oem one popped out easy. the axle in it right now is a gsp but i need to swap axle and this is why i am currently attempting to do this
i had the same problem once.. wouldnt come off for the life of me.. but after alot of banging on it then wedging in a ball joint folk and hitting that with a hammer it finally came out.
i finally got it out an hour later that day, i called my buddy over, he put pressure on the pri bar and i hammer the pri bar to make an impact and it poppedrite out
use a small pry bar and hold inner cv joint straight. should pop out. alot of times when u pry it from one side it cocks a little bit preventing it from coming out. (hold it straight and pry)
