Go Back   6th Gen Accord DIY and Performance Forums > The Garage > URGENT - Help Quick!
URGENT - Help Quick! Car won't start, or having another issue and hoping for an answer right away? Post in here for the quickest response.
Register to remove these ads
Reply
  #1
Old 05-19-2017, 03:25 PM
haoleflip haoleflip is offline
Points: 7,165, Level: 25 Points: 7,165, Level: 25 Points: 7,165, Level: 25
haoleflip is an unknown quantity at this point
99 accord lx v6 rough idle, engine power stuttering
Hey guys, it's been a while since I had to come here for help on issues cause my car has been running great until now!
I have a sort of rough idle and whenever I drive I sometimes lose acceleration power completely for a few seconds and I have to push the gas harder to get acceleration going again. Engine is throwing me and every shop I go to (been to 3 different ones) P0401 EGR valve code. I have replaced the EGR valve twice, along with cat and O2 sensors. The first EGR valve I bought I thought was bad, since the issue persisted after I installed it, so I bought another brand new and still having the issue. The code also says that it could be a blocked line that leads to the EGR valve, so I took off all of the lines I could see and sprayed air through them and they all seem fine. I don't know what else could be the problem! Help!
  #2
Old 05-19-2017, 04:46 PM
WHEEELMAN's Avatar
WHEEELMAN WHEEELMAN is offline
Senior Member
Points: 12,647, Level: 33 Points: 12,647, Level: 33 Points: 12,647, Level: 33
Activity: 2% Activity: 2% Activity: 2%
WHEEELMAN is more helpful than most
Member Photo Albums
Re: 99 accord lx v6 rough idle, engine power stuttering
Did you visually inspect the EGR port on the side of the cylinder head as well as the intake manifold EGR port for junk that may be blocking one or both ports?
  #3
Old 05-21-2017, 01:21 PM
eksine eksine is offline
Junior Member
Points: 4,391, Level: 19 Points: 4,391, Level: 19 Points: 4,391, Level: 19
eksine is an unknown quantity at this point
It sounds like the idle air control is dirty or broken, but thats just a guess, you also might have not clean the egr port good enough, the air circuits also get blocked, looks like an ant maze and if u got it blocked down the egr hole you have to take off water passage to clean it out, you moght have sent the blockage down there
  #4
Old 05-23-2017, 11:28 PM
Rusty Accord Rusty Accord is offline
Senior Member
Points: 867, Level: 7 Points: 867, Level: 7 Points: 867, Level: 7
Activity: 100% Activity: 100% Activity: 100%
Rusty Accord is an unknown quantity at this point
It sounds like you'll have to pull the upper part of the intake manifold, and clean the EGR port. I only say that, as just replacing or blowing air thru it won't do it. I don't have any experience on the V6 engine, but on the I4 engine you separate the upper so you can get to the spot where the build up is. Then you clean both passages.
When I did it on my wife's 00Accord, I had to replace the valve after cleaning the port (I did it before too, but it was a bad one). Since then, no engine codes have come up.
__________________
Bob 1997 Accord LX sedan w/ 5 speed F22b2 235K miles currently for sale
1999 Accord LX sedan w/ 5speed F23A1 LEV 232K miles
Sue's 2000 Accord LX sedan AT F23A1 LEV 235K miles
  #5
Old 05-29-2017, 05:18 AM
Thanks for the answers guys! I followed this guy in this video and I'm still having the issue. I need to get a long snake wire brush or something and take apart again, because I might have no cleaned it all the way through.
Reply
Bookmarks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
» Featured Ride
