Go Back   6th Gen Accord DIY and Performance Forums > The Garage > DIY - Do It Yourself Forum
DIY - Do It Yourself Forum We have a lot of threads on how to do things yourself, from air intakes to suspension, brakes, even electronics. Please search first, if you can't find an article about what you're wanting to do just ask for help
Register to remove these ads
Reply
  #1
Old 04-06-2012, 12:43 AM
carbonaccord carbonaccord is offline
Junior Member
Points: 93, Level: 1 Points: 93, Level: 1 Points: 93, Level: 1
carbonaccord is an unknown quantity at this point
How to fix your SRS light caused by driver seatbelt buckle
Hey guys, so I finally got around to fixing my SRS light. If you don't know how to read SRS codes here's a DIY:
http://forums.clubrsx.com/showthread.php?t=636707
How to reset the SRS light:
http://forums.clubrsx.com/showthread...ight=srs+reset
I got a SRS code 9-3 which is for the driver seatbelt buckle switch. Stealership wants $100 to read the code, and the part is around $100 + labour. My car is out of the extended seatbelt warranty. I have no idea how long the transmission is going to last, so I'm trying to save money on repairs.
The switch is just there to tell your car your seat belt is connected. This is for the airbag to determine how fast it should deploy in a crash etc. The switch is not serviceable, so you have to replace the whole belt buckle.
USE THIS AT YOUR OWN DISCRETION! You will lose the seat belt reminder light and chime.
This trick fools the SRS system into thinking your seat belt is plugged in all the time! If you always wear your seat belt then this method should be safe, if you don't then the airbag will still think you are wearing your seat belt and deploy at full force. So if you plan on not wearing your seat belt do not use this method!
My DIY fix total cost: $1.20 , takes about 15 mins for the whole job.
Parts:
1.
Go to a electronics / hobby store or Radio Shack and buy an 1 M ohm resistor. (1 M = 1 Mega = 1,000,000 ohm)
2.
A paper clip or speaker wire (3 inches is enough)
Steps:
It's optional to disconnect the negative battery, do it to be on the safe side, make sure you remember your radio code.
1.
Move seat forward and all the way up. Look under the seat from the rear, and find the buckle switch connector. Disconnect the connector by pushing down on the tab.
2.
Look at the female side of the connector, which is the one connected to the main harness. Plug in your 1M ohm resistor to the pin 1 & 2. The black wire is pin 1.
Plug in your speaker wire or paper clip to pin 1 and pin 3. Make sure they fit nicely together.
That's it. Follow the link above and reset the SRS light. If you did it right, the light should stay off. If the connections are not tight, the light will come back on right away.
If the light is staying off after you do the reset, then use black electrical tape to seal the pins and the connector.
  #2
Old 04-06-2012, 12:47 AM
20-CG5-01's Avatar
20-CG5-01 20-CG5-01 is offline
KanomNom
Points: 13,489, Level: 35 Points: 13,489, Level: 35 Points: 13,489, Level: 35
20-CG5-01 is more helpful than most
Re: How to fix your SRS light caused by driver seatbelt buckle
Nice a DIY as first post, will use if I run to the same problem.
__________________
DIY Polishing Wheels|Members Ride
"Ideas are cheap, but accomplishing it is expensive"
  #3
Old 04-06-2012, 12:49 AM
Junior Member
Thanks, I'm more active in my local accord forum. I just figured this site gets more exposure. Maybe this DIY will help some people save some money.
  #4
Old 04-06-2012, 08:57 AM
02accordcoupe 02accordcoupe is offline
Senior Member
Points: 4,895, Level: 20 Points: 4,895, Level: 20 Points: 4,895, Level: 20
02accordcoupe is an unknown quantity at this point
I'm pretty sure anything seat belt related is covered under a lifetime warranty due to liability issues. At least that is what Crown Honda told me. I had mine fixed for free back when I first got the car. It came on shortly after I bought the car.
__________________
2002 Accord Coupe SE 2.3 I-4 AUTO
137,xxx miles
1992 Lexus SC400 84,xxx Miles *my toy*
http://www.6thgenaccord.com/forums/s...ad.php?t=38870
  #5
Old 04-06-2012, 11:24 AM
Junior Member
Yes I think for the US this is true. For Canada we only get 10 years or something...
  #6
Old 04-06-2012, 05:32 PM
Senior Member
Ah ok.
__________________
137,xxx miles
  #7
Old 04-06-2012, 06:07 PM
AllGOnoSHOW AllGOnoSHOW is offline
Banned
Points: 38,196, Level: 60 Points: 38,196, Level: 60 Points: 38,196, Level: 60
AllGOnoSHOW should be someone you can trustAllGOnoSHOW should be someone you can trust
Nice right up man
  #8
Old 04-07-2012, 01:45 AM
CG6>YourCar's Avatar
CG6>YourCar CG6>YourCar is offline
Senior Member
Points: 3,089, Level: 16 Points: 3,089, Level: 16 Points: 3,089, Level: 16
CG6>YourCar is somewhat reliable
Honda felt guilty about screwing over the Americans, so, Canadians get all the extra goodies, BUT 10 year warranty. Americans get close to jack **** but, we get lifetime warranty.
__________________
Self proclaimed as head noob of the nooblets on 6GA
Have you seen the wheelgap on these cars? You could fit an infant in there. - truWarier02
  #9
Old 04-07-2012, 01:57 AM
slowrider87 slowrider87 is offline
Senior Member
Points: 7,635, Level: 26 Points: 7,635, Level: 26 Points: 7,635, Level: 26
slowrider87 is somewhat reliable
Yes nice write up!
i have one for the american population...
http://www.lmgtfy.com/?q=local+honda+dealers
find closest one, call them, tell them your problem. take it in.
__________________
  #10
Old 05-16-2013, 09:44 PM
blown alcohol blown alcohol is offline
Junior Member
Points: 2,421, Level: 13 Points: 2,421, Level: 13 Points: 2,421, Level: 13
blown alcohol is an unknown quantity at this point
How many has done this mod?
I am going to do this, or try and find a used seat belt buckle local. The thing is in time it will fail again.
Local Honda dealer quoted $165 labor plus cost of part. I called Honda customer service, and it is not covered under any warranty.
Reply
Bookmarks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
» Featured Ride
Congratulations to Michael for winning 6GA's ROTM of the Year. Click the picture below for more pictures as well as an exclusive interview with the winner!
