Go Back   6th Gen Accord DIY and Performance Forums > The Garage > DIY - Do It Yourself Forum
DIY - Do It Yourself Forum We have a lot of threads on how to do things yourself, from air intakes to suspension, brakes, even electronics. Please search first, if you can't find an article about what you're wanting to do just ask for help
Register to remove these ads
Reply
  #1
Old 01-20-2009, 12:15 AM
juicebox00's Avatar
juicebox00 juicebox00 is offline
Senior Member
Points: 31,741, Level: 54 Points: 31,741, Level: 54 Points: 31,741, Level: 54
juicebox00 has their shit togetherjuicebox00 has their shit togetherjuicebox00 has their shit together
Member Photo Albums
Send a message via AIM to juicebox00
Full DIY 01-03 JDM civic fog lights install
Ok, so basically this is the entire process that I did to install the civic fogs. This is what the final product looks like.
This is the basic diagram for this set up.
Everyone installs the fog lights there own way onto the bumper. Personally i cut out the end of the inside of the bumper and used L brackets and a screw through the bottom of the bumper to hold the fogs on.
So basically after that you start out with this harness (pic by younglemon)
First, after installing the fogs on the bumper and plugging them in to "A" and "B"(personally i had the wire the other way around), you want to find ground points for the two ground wires on that section. next i ran the wire of "D-F" up through the engine bay by means of where the intake is (on the v6 model)
Then i ran wire "D-F" on the "F" side through the firewall since "D" will be connecting to "C". There is a point in the firewall that is very good for this specifically shown here.
In order to use this hole you need to pop out a cap that looks like this
And to pop it out you need to push is with something like a screwdriver from the inside of the car. It is located slightly to the right of the steering wheel column underneath the dash. There is a little pre-cut hole in the firewall padding on the inside that you pull away to get to the tab. To get to this area you need to lay down by the pedals and look up.
Once you feed the "F" side of wire "D-F" through you pull it down and it will look like this.
You might have trouble feeding "F" through the hole because there could be 2 plugs on the end of "F". Find out which plug is connected to "E" and you can cut that off. Double check to make sure you're cutting the right wire though.
Once you've done this you're now on the last section of wire. This is where you need to do a little bit of splicing. What you need to do is connect the two wires highlighted.
In order to do the next couple of steps you need to take off the button section and to do this you need to pull out the coin tray and unscrew the 4 screws located there. Once the four screws are out all you have to do is pull out the entire section including the air vent. It made be a little stern but it'll come out.
Now where to plug in the last wire section. "F" is going to connect to "G" and "K" will be connected to the fuse box under the steering column. This is exactly what "K" connects to. You probably want to connect it to the bottom left slot (I only suggest here if you have an aftermarket radio thought) which is also works on the same power as the radio so if you can turn the radio on you can turn the fogs on. And by plugging it in the bottom left slot you may blow a "7.5" fuse (if you have a factory radio) that will make your radio not work but it is only the acc. fuse located in drivers side fuse box. So you'll just want to replace that fuse with a "10" fuse. do not use the bottom right! And the upper right area is on the same power as the ambers so you can only turn you fogs on when your ambers are on and when plugging it in there you will most likely blow the fuse for the ambers which is a "10" fuse located in the passenger side fuse box. To avoid it blowing you want to replace it with at least a "15" fuse and nothing more. Put higher fuses in at your own risk though because you aren't usually supposed to replace fuses with more powerful ones, but a slightly higher one should be fine. Upper left is unknown at this point. Also, when you connect it you want to put it up side down compared to how you think you would connect it.
You also want to ground the ground wire on this section of the wire and where i grounded it was on the steering column as shown here
"H" is where you connect the relay which should come with the fog lights. You'll then pull "I" and "H" up through the wires to where the button area is.
All that is left is to plug the button into "I' after feeding "I" through the hole in the button panel and close it up as well a putting the bumper back on and checking that all the connections are good.
Another thing you may want to do is drill holes into the bottom of the bumper so that you can use a screw driver to adjust the fog lights once the bumper is on the car.
You won't need to plug "J" into anything as well as "E" which will also have another part that comes out by "F".
And if you have an OEM fog light switch that you want to use instead of the civic switch use this set up by Russianred
http://www.6thgenaccord.com/forums/s...ad.php?t=17016
I deserve rep points for this epic write up, plz.
__________________
HID Kit Club #087 | TWM#008:TLMF | Civic Fog Club #001
SoCal Ninja
  #2
Old 01-20-2009, 02:10 AM
Dtownz Thrillah's Avatar
Dtownz Thrillah Dtownz Thrillah is offline
Senior Member
Points: 5,985, Level: 22 Points: 5,985, Level: 22 Points: 5,985, Level: 22
Dtownz Thrillah is an unknown quantity at this point
Re: Juicebox's full DIY 01-03 civic fog install
It would be epic without blurry pictures, a diagram and no MS paint =]
  #3
Old 01-20-2009, 01:17 PM
CG6Lemon's Avatar
CG6Lemon CG6Lemon is offline
Detailing Enthusiast
Points: 43,710, Level: 64 Points: 43,710, Level: 64 Points: 43,710, Level: 64
Activity: 3% Activity: 3% Activity: 3%
CG6Lemon is somewhat reliable
Member Photo Albums
Send a message via Yahoo to CG6Lemon
lol gratz on a write up. rep points for joo son
__________________
DetailedByPrecision
Paint Correction - Ceramic Paint Coatings - Auto Detailing
Serving San Francisco Bay Area
Phone: 415-601-4291
Follow us on: Facebook
https://www.facebook.com/DetailedByPrecision
Follow us on: Instagram
https://www.instagram.com/detailedbyprecision
  #4
Old 01-20-2009, 01:47 PM
juicebox00's Avatar
Senior Member
Member Photo Albums
I'll take new pics with a real camera, the paint is to show the exact thing i was showing. And i think i'll just edit a copy of lemon's pic as a full diagram even though it is self explainatory if you read the text
__________________
SoCal Ninja
  #5
Old 01-20-2009, 03:47 PM
olivesomra's Avatar
olivesomra olivesomra is offline
Senior Member
Points: 6,348, Level: 23 Points: 6,348, Level: 23 Points: 6,348, Level: 23
olivesomra is more helpful than mostolivesomra is more helpful than most
Also a diy on NOT using a fog switch. Just a connection to the secondary lighting. If possible.
__________________
<a href="http://www.6thgenaccord.com/forums/showthread.php?t=14265"><img src="http://i760.photobucket.com/albums/xx243/olivesomra/NEWSIG.jpg"></a>
  #6
Old 01-20-2009, 04:18 PM
juicebox00's Avatar
Senior Member
Member Photo Albums
I think all you do to do that is splice the "D-F" wire with one of the turn signal lights or the lower amber light. Don't take my word for it since i didn't do the set up that way. So I don't necessarily want to put that on my DIY. If someone can post a set up for doing it that way i'll post it up.
__________________
SoCal Ninja
  #7
Old 01-20-2009, 04:38 PM
Russianred's Avatar
Russianred Russianred is offline
Snail Spools You!
Points: 50,075, Level: 69 Points: 50,075, Level: 69 Points: 50,075, Level: 69
Russianred is a name known to allRussianred is a name known to allRussianred is a name known to allRussianred is a name known to allRussianred is a name known to allRussianred is a name known to all
Member Photo Albums
Send a message via AIM to Russianred
Arrow Re: Juicebox's full DIY 01-03 civic fog install
Why the fk would you want to do that?
I could never understand that.. just do it right, it's not hard. One day you will want to turn the fogs off and won't be able to, or you'll get pulled over by an asshole cop, questioning your foglight use in regular weather. It's happened.
Just connect them the right way. For the awkward position you need to bend in to feed the wire, it's worth it.
Good job JuiceBox! Finally a wiring schematic for the infamous civic fogs!
Rep for you.
  #8
Old 01-20-2009, 04:52 PM
juicebox00's Avatar
Senior Member
Member Photo Albums
Rep for you.
If anyone wants to wire a OEM fog switch to their civic fogs, my writeup is found here:
Thank you, and i put your link to the oem switch on my post
__________________
SoCal Ninja
  #9
Old 01-20-2009, 05:35 PM
henreeezy xp's Avatar
henreeezy xp henreeezy xp is offline
Senior Member
Points: 18,146, Level: 41 Points: 18,146, Level: 41 Points: 18,146, Level: 41
henreeezy xp is more helpful than most
Send a message via AIM to henreeezy xp
can you be more specific on the part where you started splicing and plugged that wire to the fuse box? and did you splice anything to the turn signals or anything like that?
__________________
C.L.A.S.S. 6
TWM Honorary Member | UTI Club Member #1 | LNC Member
  #10
Old 01-20-2009, 05:56 PM
juicebox00's Avatar
Senior Member
Member Photo Albums
All i did was splice the two wires shown together, I did not touch any wires that were already in the car such as the turn signals. i will be putting up better pics of the exact location of the fuse box and where to plug in the wire.
*Edit: pics up
__________________
SoCal Ninja
Reply
Bookmarks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
» Featured Ride
