Cluster Problem HELP!
yo44boichris
Austin Texas
so I was changing out my ground wires to 0 gauge ones. When I got done, my cluster arrow for my rpm some how fell below the 0 like its just hanging down. When I turn on the car it moves up, but something is blocking it from going up, so it says at 0 the whole time. I don't know how it got below that marker, what should I do...?
CG6Lemon
Detailing Enthusiast
S.F Bay Area, CA
you know there's a thing that prevents it from dropping to a certain point right? the little thing that the rpm needle sits on. did you take off your cluster when changing out the wires?
CG6Lemon
S.F Bay Area, CA
so are you saying your rpm needle is under the plastic thing that prevents it from jumping back up? if yes then you're gonna need to take off the cluster to fix it. the rpm needle can spin backwards back to the top again. you will have to shake it somehow to spin back to it's original position.
G'sAccord01
North Jersey
to take my cluster out i had to take apart the plastic around the steering wheel bcaz ontop of the steering wheel behind a plastic flap thing theres 2 more screws
