Apr 30, 2015 #11 J james'99 Well-Known Member Joined Dec 27, 2013 Posts 1,584 Reaction score 9 Location East Fishkill, NY How bad was the oil on the plug? How old are your spark plug wires?
Apr 30, 2015 #12 xci.ed6 Well-Known Member Joined Sep 5, 2007 Posts 2,909 Reaction score 9 Location Tampa Bay yes oil does cause a misfire on the plug wires, a short to ground, so no power gets to the plug. ditto his question, but how old is your valve cover gasket?
May 1, 2015 #13 X xlino Well-Known Member Joined Apr 5, 2013 Posts 60 Reaction score 0 Location Hawthorne I have not changed the valve cover gasket since 130k. Now i have 155k. I will try that and change the wires. The wires where changed around 145k. How often do you have to change the wires? The spark plugs had a little of oil on cylinder 3 and 4
May 9, 2015 #14 J james'99 Well-Known Member Joined Dec 27, 2013 Posts 1,584 Reaction score 9 Location East Fishkill, NY xlino said: The wires where changed around 145k. How often do you have to change the wires? Click to expand... I don't use an interval so much as inspect them and clean them every so often. Yours only have 10k. Should be fine. Depends on brand though.
