ib042129
1)Does the handbrake light go on from other sensors not just the handbrake?
Recently it would not turn off for a while in cold weather. And yesterday it came on randomly on the highway. The car does not feel any different, nor
do I smell brakes burning. Is it just the sensor being weird, or will my breaks fail and I will die pretty soon?
2)I think my clutch is about to be worn out. It's fine when I drive like a grandma, but when I shift quickly the RMP do not imediatly jump to whatever they are supposed to be at that gear and speed, but instead creep to the corect value over a second. The clutch works fine once engaged though.
Anyways, my father thinks that you can adjust the clutch pedal like you could adjust the handbrake line for worn out pads and have the clutch last a bit longer.
So can I adjust the clutch in that way?
And,
How many more miles do you think I have before it goes?
THanks
And,
THanks
