hellfire127
There seems to be an oil leak under the passenger side of car. I think it's been leaking for past year or little more. Just haven't had time to get to it until this week. I've had to add some oil to the car 3-4 times since it started.
The car did give me a code reading in the past and I believe it was due to low oil pressure. The oil level was low and I pour some oil in the car and reset the code. It was driving fine since then but slow leaks still occurred.
Fast forward to this week, I was driving back from out of state (5 hrs) and then P1259 code came on(not sure if same code as before). Noticed that oil level was low again and pour some more in. Oil level is good now.
I've looked in in the past and looked again today but can't seem to find where it's leaking. I think it could be coming from the lines under the car. I took some pictures but not sure if you guys can tell.
Also another question not related to the oil leaking but figured it's better to ask here than create another thread.
My car hesitates sometimes when I press the gas after stopping at stop sign or first starting. The RPM would go up but the car doesn't seem to want to move then suddenly shoots forward. After that it starts driving fine. Not sure when it started but it has been a while.
1999 Honda Accord 4 cycl. 184k miles. Haven't done anything major right before the leak. The tranny was rebuilt at 160k if I remember correctly. Power steering and brake fluids have been replaced in the past along with head cover gasket.
oil leak pictures
oil leak pictures
