ok my car is a 98 v6 sedan. was driving last week and my upper radiator hose cracked right were it meets the motor, i had to do a side road quick fix by cutting an inch off the end and putting back but in doing so i had to remove the plug for the iac to get to the hose clamp off and quite a bit of Hot anti freeze got into the sensor. after that i was running wierd shifting wierd and throttle response was rough wen acclerating and decelerating and under full throttle it completly chokes up can only just cruise around right now, was wondering if i can just clean it or is it completley shot and need a new one? . would rather fix because there not that cheap , any info would help, thnx
