Lloyd
I'm on the upside of my tranny swap now on my '98 coupe. Tranny is installed now....I was in the process of routing my shifter cables over the transmission when I realized that they must come through or around the rear engine mount bracket. I had the A/T mount still installed and there looked to be no clean way of routing the cables....SOOOO I had a look at the M/T mount and sure 'nuff....there's 2 holes in the bracket for the cables to pass through.
Since I have it, I am about to install the the M/T rear mount.
My question is about the fancy valved/electonic rear mount. IF I plan to use a manual ECU anyway ..would the A/T electronic mount still function?...Or would it become just a dead mount ...Is it just as well that I go ahead and install the M/T rear mount with it's better cable routing?
Thanks for any info
Lloyd
Thanks for any info
Lloyd
