igrindnonstop
I also agree that it is unlikely that all bulbs went at the same time. Is your third brake light also not working? I'm pretty sure that the third brake light on our accords is run through a separate circuit so I doubt its the fuses. Check the brake switch
I had one go bad on my car causing the brake lights to intermittently work and my cruise control also stopped working.
VancouverAccord: I will check my third brake light as soon as i get off work, but I will check my cruise control as well. i never really use it to stop and go traffic. If it does happen to be the Brake Switch. Is it something that is fairly easy to D.I.Y? Thank you for the advise.
