CAI Honda Accord 2002 DX Need help in regards to water damage
Eatmydust
Miami
Hi, I am new to the forums and I drive a 2002 Honda Accord DX. I recently purchased a CAI but its not named brand. I have been hearing alot of stories about water getting sucked in if u install it where the resonator used to be. My CAI will be comming in on wednesday so I wanted to know if It is safe to install it where the resonator used to be as I want to optimize HP gain. However, my street sometimes tends to get flooded quite a bit so will that affect the CAI? Thanks. Oh and if you can also link me to any good CAI install DIY threads I would really appreciate it thanks.
Eatmydust.
BadgerType
Resident ***hole
SW FLA
you will be fine as long as you don't submerge the filter, aka drive through a pond
Mojeans69
Tha Bean
thsi has been covered plenty of times...it does mount down behind the front bumper...how low is your car...if its not dropped i wouldnt worry about it also you can get a bypass valve which will stopped the water from being sucked in if the filter is submerged..I had a CAI for 5 years no problem
What Badger said. Btw an intake will do nothing for power, especially without VTEC yo.
Eatmydust
Miami
ok thanks guys very helpful. Right now its sitting stock but im thinking maybe some ksports springs? i just want like a 2 inch drop not to slam it. So should i get the bypass valve just in case? I'm not lowered whatsoever..
Chris Vu
So*Cal
if you're not lowered, you're gonna have to drive through a pretty deep puddle in order for it to suck up enough water to damage anything. Don't worry about it and slap that ***** on there. i've had my cai on for 4+ years but also have an sri for the winter season, so that's always an option for oyu, but i never change mine out unless it's raining hard .. and i'm pretty low to the ground ..
AllGOnoSHOW
asdfasdfasdf
Before you make any more purchases that you aren't 100% sure on Research and ask any questions before you make the purchase. Trust me it'll make things go a lot smoother. I know from experience. My philosophy is why get a CAI where there is a tiny possibility of hydrolock over a SRI where there's practically no risk. Most of the time with just an intake your going to lose power anyways especially in a lot of our cases, unless paired with other supporting mods. I get it tho, you are just wanting the sound. I'm just sharing my .02
knighthawk1104
New York City
I have the Injen CAI so i bought the "hydroshield" for safety. im dropped 2.5 in the front and no problems so far.
jwong512
Socal 626
If your afraid of hydrolock but don't want the heatsoak that you would get from a SRI, I would highly recommend getting a Taspro Hybrid Intake from tasauto.com. It uses aftermarket tubing so it's smoother but utilizes the stock air box with a K&N drop in filter. I personally have that on my car and I think it gets the best of both worlds. I hacked off the bottom of the airbox so I can get maximum air suction and since it's focused on the bottom it only sucks in air from the fender liner. It also has the response of a SRI and doesn't get heatsoaked since the plastic airbox doesn't heat up as easily.
It's the best intake and cheapest intake for our cars IMO.
