diy help for 2002 sedan tail light clearing amber/yell
bX aCcOrd
Bronx
i got a 2002 sedan and i wanna to clear the little amber/yellow blinker spot so the bottom will be stright clear and the top will be red
JMillerUA6
Grillin' rape steaks
W. Hartford, CT
Take the tail lights off the car, and bust out the amber bulb cover thing with a screwdriver. Then shake the shrapnel out.
Or
You can put them in the oven and take them apart, remove it, then seal them back up.
98akkordLX
Nashua NH
Actually a REEAALLLY good way to do it:
Take a soldering iron and burn a * shaped star grooce on the plastic amber piece. And then take a screw driver and a light hammer or mallot, and punch it with the screw driver, and the amber piece will shatter into little pieces, then you just have to flip the headlight and let all the pieces fall out, if some piece gets stuck, use a needle nose and break it into smaller pieces and pull it out. and ur clear tailz are dunn!!
ditbu13oi
San Jose
I did that also.. Had nothing but time... =D
