door lights on, brake light, bad alternator connector?
jtboost59
AZ
I actually dont know if i fried my alternator wire to fuses because i keep getting door lights on, brake light, and solid check engine when watching for blinks. I had an electric AC system connected and when i stalled out, my Accord didnt start after. Ended up replacing the distributor and that got the car running(weird cause had door lights stuck on). I already tried a new alternator but that didnt work and also new power wires from battery to starter/fuse box and new ground, new battery. Should i be getting full 12v battery power to the alternator connector pins? im getting 12.7 on one pin, 11.8 on another, other 2 are grounds right? dont know if below 12v is bad? Also check out photos of new battery wires, dont know if this accord can be hooked up that way, thanks. i have a 2001 accord 2.3 f23a1 manual, modded with turbo, electric ac(taking off) lol. running flex fuel on neptune, obd1. i have the top post going to the fuse box, and bolted wire going to starter. i had everything working at one point, electric AC, turbo setup working good for almost 2 years
jtboost59
AZ
im swapping distributors cause i put a cheap one from amazon on to get the car running, so hopefully its that lol
