Driver/Timing side oil leak
Discussion in 'URGENT - Help Quick!' started by JFISHTHECREATOR, Nov 22, 2015.
  1. JFISHTHECREATOR
    JFISHTHECREATOR Well-Known Member
    65
    Oct 29, 2014
    Reynoldsburg, Ohio
    Welp , here we go again. 1999 LX Sedan F23A1 5MT.
    I drove this thing over 150 miles(with Bardahls no smoke in oil) to see a DB2 that wanted to trade.I had no issues there , or while he was test driving the car. I drove it home with the oil light coming on , I would turn the car off and coast in neutral so the car could cool down and that way no oil could be burning.
    Got home put a quart in and left it. Started it 3 days later and it started puking oil on the driver side. I thought it was the balance shaft seal due to excessive oil pressure from the additive.
    I took the upper timing cover off and didn't see the seal popped out. However , I started the car and saw oil lubing that , and dripping down and onto some other bolt/shaft underneath of it.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    I can't tell where it is leaking exactly. The pics I took aren't the greatest seeing as i could barely fit my phone down there, and lighting is inadequate even with a flood light , and or phone flash.
    On the bright side, the T-belt looks good lol....
    [​IMG]
  2. Sino
    Sino Well-Known Member
    120
    Nov 30, 2014
    Massachusetts
    When I started my engine after the machine shop had put in seals the cam seal pissed out oil. It's not too hard to have the lip of the seal roll on installation. Clean up the oil as much as you can and if you can have someone else start the car you can try and see where the oil is coming out of before it gets tossed around onto everything.
  3. JFISHTHECREATOR
    65
    Oct 29, 2014
    Reynoldsburg, Ohio
    Just wanted to update this. I traded the car for a 95' accord coupe with a H22A and have been going thru getting it running instead, to swap into my 91' accord. I did, however,get another 6th gen.. grabbed a 2002 accord ex coupe v6. I bought it cheap with a trashed transmission. I rebuilt the transmission, as well as the whole suspension, brakes, did the timing belt water pump VC gaskets etc. just a major tune up, trans is still strong 30k miles later! I will have to post pictures of it.
  4. Nam1911a1
    Nam1911a1 Well-Known Member
    495
    Aug 16, 2016
    Southern Indiana
    Did you rebuild the transmission yourself?
  5. JFISHTHECREATOR
    65
    Oct 29, 2014
    Reynoldsburg, Ohio
    Yes I did. It wasn't bad at all.
  6. JFISHTHECREATOR
    65
    Oct 29, 2014
    Reynoldsburg, Ohio
    The CG2 V6 Coupe
    This is the new 6th gen I bought. I rebuilt the trans and did all kinds of maintenance on it to get it up to par. I also lowered it, and made a custom single exit exhaust.
    List of Maintenance done
    • New Kumho Ectsa 4X tires - Lasted 30k Miles, 45k mile warranty
    • New TOYO Extensa A/S tires - 65k mile warranty, 2k Miles on them so far
    • Timing Belt, Water Pump, Tensioner, Idler
    • NGK V-Power Spark Plugs
    • Valve Cover Gaskets
    • PCV Valve
    • Cabin Air filter (X2)
    • Front/Rear pads and rotors (cheapo DURAGO/MONRO from rockauto)
    • Front/Rear pads and rotors (Advance Auto Rotors/Centric StopTech Sport Pads)
    • Front Lower Ball Joints (2X)
    • Front Upper Control Arms (3X)
    • All Engine/Trans Mounts (Side Mount 2X)
    • Primary and Secondary Oxygen Sensors
    • Rebuilt Power Steering Pump
    • High Pressure Power Steering Line
    • Transmission Fluid Flush (3x 3Quart each time) (1 Time before rebuild, 1 Time after rebuild)
    • Engine Oil Pan
    • VTEC Solenoid Gaskets
    • Kemso 340LPH Fuel Pump
    • Idle Air Control Valve
    • Thermostat
    • Engine Coolant Temperature Sensor
    • Clean Intake Manifold and Throttle Body
    • Re-Finished Headlights
    • 2.5 Inch Exhaust Custom Bent by Me to Ebay Chrome Muffler
    • Driver Seat Rear Entry Cable
    • Purple VTEC Lights ran into Side View Mirrors
    • 03-07 Accord 4CYL Rims
    • Left Front ABS Sensor
    • Lowered on LoTek Springs with TruHart Struts
    • Rebuild Transmission
    • Raybestos Frictions/Steels
    • TransLab .388 Shift Correction Kit
    • Filter
    • Clean/Reuse Solenoids/Switches
    • Castrol TransMax Import Multi-Vehicle
    • Hayden 514 Oil Cooler (Transmission Cooler, Deleted Factory Cooler)
    • JVC KW-X830BTS Double Din Radio
    • Cerwin Vega XED Door Speakers
    • Cerwin Vega HED Decklid Speakers
    I am SURE I am missing a few things. But here it is.
    2018_08_09_IMG_7732.JPG 2018_08_09_IMG_7734.JPG 2018_08_09_IMG_7737.JPG 2018_08_09_IMG_7738.JPG 2018_08_16_IMG_7977.JPG
Share This Page
