Drop help
If you look under your car, follow the rear sway bar to one end, and at the end of it you'll see a cap with 4 circles on it which is linked to to another cap above it with the same circles. Your OEM endlinks are about 5 inches long.
The endlinks provide a connection between your sway bar and the suspension. There is a sort of ball joint inside each of those caps that alllows movement with suspension travel. If you look in the front, you'll see the same thing (obviously a different set up).
Momentum
Texas
oh okay. So it kinda adapts to how you drive, turn, etc, i guess you could say?
The sway bar controls your body roll, and since the suspension travels up and down the link needs to move with it, which is aided by the ball joint (since the RSB and suspension are connected by the link).
I'll try to post a photo showing the connection.
