604ACCORD
I was not going to do this but what the hell. This is to make your trunk bright as day.
Parts needed:
Wire, I think mine was 14ga
3 or 4 led strips, one of mine is alpena other 2 are cobb
Heat shrink
Zap straps
E tape
These are the lights I got from ebay for 10 bucks
Here's the link
http://www.ebay.ca/itm/141984909039...49&var=441104411205&ssPageName=STRK:MEBIDX:IT
So find the oem trunk light and remove it and unplug, I cut off the connector
Looks like this
There is tabs on the side u gotta push them in
So on mine white is ground and orange is hot
Check on your with power tester
Next mount your leds. I put 1 on each side and 1 in the middle. Run all your wires to the center where the trunk light wires are, try to hide them as best you can my pass side was a *****. Make sure they are secured good.
Here's how I ran my sides and where I installed them. They came with 2 way tape.
This is my center one I installed before
Wiring
Pass side
Driver is up here
Meet them up with the oem harness. Solder and heat shrink them up, make sure you test everything before soldering.
Final product
For this I used a bunch of scrap wire and whitish leds, you can use any color to match your car. Any questions feel free to ask.
Pros
Bright
Looks killer
Cons
Now I see how dirty my trunk really is
Parts needed:
Heat shrink
Zap straps
E tape
Here's the link
Looks like this
Wiring
Pass side
Driver is up here
Final product
Pros
Bright
Looks killer
Cons
