Leonhart306
I have a 2002 Honda Accord SE and I plan on doing the F20B swap, despite everyone wanting me to go with a H22A. This will be my daily driver. I found a seller that is currently selling a F20B and listed the following parts. I've sent an email to the guy about what else I would need, but he wasn't sure so I thought I would ask here. I would kindly ask to stay on topic and not talk about the H22A here. Thanks a lot! Does anyone know if I would need any other additional parts aside from below?
ENGINE BLOCK
5 SPEED LSD TRANSMISSION
INTAKE MANIFOLD
EXHAUST MANIFOLD
FUEL RAIL
THROTTLE BODY
VTEC SOLENOID
DISTRIBUTOR
ALTERNATOR
STARTER
AC COMPRESSOR
POWER STEERING PUMP
INJECTORS
SPARK PLUGS
OIL PAN
DRIVE SHAFTS
SHIFTER CABLE
VALVE COVER
USED MIDSHAFT
ECU
WIRE HARNESSES
STOCK MOUNTS AND SENSORS
ENGINE BLOCK
INTAKE MANIFOLD
EXHAUST MANIFOLD
FUEL RAIL
THROTTLE BODY
VTEC SOLENOID
DISTRIBUTOR
ALTERNATOR
STARTER
AC COMPRESSOR
POWER STEERING PUMP
INJECTORS
SPARK PLUGS
OIL PAN
DRIVE SHAFTS
SHIFTER CABLE
VALVE COVER
USED MIDSHAFT
ECU
WIRE HARNESSES
