f23 starting problem HELP!
KingVlad
Oshkosh, WI
Hey guys having a little problem. When I went to start my car this morning it wouldn't start right away. The motor would turn over and get up to about 1k then it would just die. I tried to start it about 4 mire times with no luck. I finally got it to start after a while by holding the gas down and letting it get to about 4-4.5k where it would finally hold the rpm at the usual 750. I turned my car off again after driving about a Mile and had the problem again where it took me about 10 tries to finally get it to go. Any of you had the problem before? My tank is on E but nothing major, ive had it start just fine on less gas. Not a cold day today either ~70 degrees. Not sure of this is the right place to post but of well.
