hard/rough shifting?
YoungxNutkase
Westside of Lynn, Mass
Hi guys I just did a 5spd swap on my car recently...I been driving my car for a while and it has terrbile shifting compare to my sisters civic....I have a stock shifter and its hard to get into all gears especially 5 and would sometime grind a lil getting into five...I swap out the stock one and put a short shifter in and that did help...but its still kinda rough, no more grind either... I'm assuming it could b my slave since the brake fluid does get kinda low and ran out once...but I don't see no signs of leaks?? I also thought that the clutch needed to b broken in but I beenn driving on the highway back and forth for 3 weeks to work so I kinda rule that out.....another thing is I think I need lube somewhere?
I don't wanna go do a shotgun method of fixing it (buying parts and end up not needing it)...
Jus wanna see everyones opionion on the problem. Then rules something out.
And yes I have bled the clutch, my accord ain't as fun as my sister civic, hers goes into gear so easy, I can multitask so easy driving it too..and my accord im driving it with the worry of having a hard time getting into gear, since I always have to SHOVE it in gear
itzcharlie
Baton Rouge, LA
im having the same problem.. i just got my clutch changed out and its really really hard to go into gear. i cant even go into reverse unless i turn off the car. i wanna know the answer to this too.
Mojeans69
Tha Bean
did you put washers behind the clutch pedal? the manual firewall is different from the auto
YoungxNutkase
Yup me and chido put a bunch of washers behind it...imma a change the slave and xring kuz the fluid is deff getting low so something is leaking..the masterr cyl is new so I rule that out...but for some reason I don't think it will help the hard shifting if i replace those parts I mention..it wouldn't go into gear this morning, the fluid was low but it wasnt out...imma replace the parts on Thursday see what that do.. what's a bad synchro?
YoungxNutkase
update - well fixed the rough shifting..added a new slave guess that did it..but still is leaking and running out of fluid..gonna try to change the xring on the masters see if that will stop
