Help! Transmission Help!
Discussion in 'Engine & Transmission Mods' started by maximus017, Mar 15, 2011.
  1. maximus017
    maximus017 Active Member
    31
    Jul 16, 2009
    Houston
    As of late, I have been noticing my car shifting very hard into reverse. I usually park my car on my driveway, and reverse back out to get out. When I shift into reverse, the car shifts very hard....but after I have driven for a lil while, and shift into reverse, the car shifts fine. no odd jerks or anything. I have checked my transmission fluid and thats fine...oil is not burnt or anything...gonna replace it soon. I was thinking it could be the reverse solenoid, but I have no clue where it is on the Tranny. Any help would be greatly appreciated...
  2. J30MAN
    J30MAN Well-Known Member
    24
    1,641
    Jun 1, 2010
    Agawam, MA
    mine clicks into drive/reverse with a slight jerk when its cold too...i think its normal. Because my dads 4Runner does it when it cold also, so I wouldn't worry too much. But yes change your fluid with Honda ATF-DW1 soon.
  3. RedRyder
    RedRyder Be a better driver
    19,200
    64
    Is where you park on your driveway a hill? If so and you're not setting the ebrake before putting the car in park, that is what's causing it to shift hard into R. And the car already will naturally jerk just a tad when shifting cold.
  4. redlinevtec
    redlinevtec Well-Known Member
    1,092
    12
    May 6, 2010
    South Orange County, SoCal
    When I had autotragic before I went 5spd, autotragic would always clunk in reverse on cold mornings. But when it was warm outside it didn't do it. And I ALWAYS used the e-brake. This was still happening after I had it rebuilt two years ago. It's just a crappy tranny...Use a tranny cooler. It actually helps. Even on cold mornings. I know it sounds stupid but it helped before it took a big dump in my wallet...lol
  5. maximus017
    31
    Jul 16, 2009
    Houston
    Its slightly uphill...Am i suppose to set the brake before I put the car in park, or after...I have always done it after??? Habit i started when i had a manual..One thing i failed to mention, even sometimes when its warm it does it too.
  6. RedRyder
    19,200
    64
    If parking on a hill, I hold the brake pedal, set the e-brake, shift the car into Park, then release the brake pedal.
  7. maximus017
    31
    Jul 16, 2009
    Houston
    Red Ryder thanks for the info...
    just out of curiousity...has anyone tried Lucas Oil Transmission Fix...supposedly stops rough shifting and other problems...Any one have an idea about this product?
  8. redlinevtec
    1,092
    12
    May 6, 2010
    Search. This product has been covered numerous times.
  9. Cg2 Snowman
    Cg2 Snowman Member
    Apr 26, 2010
    Columbus, OH
    +1
    my is like a hill. it takes away the clunking sound/feeling when putting your car into reverse from park. It will help. My friends mom actually told me to do it to prevent it :)
  10. Alis98v6
    Alis98v6 Member
    12
    May 24, 2011
    Phoenix
    Letting the car warm up helps BIG time, if my car is cold and I go from park to reverse it feels like the Tranny just feel off, I have even broken motor mounts because of it
    Sent from my Desire HD
Share This Page
