trillobite
Update: Tinypic is STILL down, so I will post images later. isitdownrightnow.com also reports that tinyPic is down today.
I woke up this morning, and found that the weather was a perfect 82*F outside, and sunny, and as many can understand, this resulted in an itch to dig into an engine. For a while now, I have been wanting to replace my IAC, as the idle is a bit irregular, which was triggering my OCD like mad. So, I finally got to do it! While I was in there, I also cleaned the throttle body, and all vacuum passages.
What I noticed was, when I pulled the upper half of the intake off, my EGR passage was highly restricted, if not blocked completely, despite not having a check engine light, or any codes.
So after spending hours spraying cleaners on the throttle body, and scraping thick carbon with a screw driver, the results were FANTASTIC! Engine knock upon acceleration was gone until at WOT, acceleration improved dramatically, and my idle is finally silky smooth!
I still need to double check my knock sensor, and find the ohms spec for it, but I have a feeling that it's always going to have a little bit of a ping or knock under WOT, as it has 250,000 miles, and probably has carbon built up in the cylinders.
Luckily I caught the EGR passage clog early, as I was able to remove the large chunks of carbon with just my finger tips, and a screw driver. Many people will wait until it's completely clogged, which causes you to have to either remove the intake completely, or use a vacuum to suck up the carbon deposits while cleaning.
