Innovative Motor Mount: 98-00 side engine mount
shenaniganz08
Los Angeles
Well looks like my side engine mount is blown (again) time to get something stiffer
if anyone know where I can get JUST the side engine mount please let me know
will even buy used
thanks
slowrider87
Northern Virginia
If you are going to switch one to a harder material you should switch them all. One being stiff and the others being soft will most likely cause vibrations still, and, in turn, premature failure of the other mounts, or even your new one. they are meant to work together.
MoneyPit
Abaddon
Richard, like slowrider said, replacing just the side mount will destroy the front/rear mounts if you keep them OEM.
Your best option would be to guy a new OEM side mount, then fill it with polyU. It will be 10x stronger, but still not overly stiff. Ideally, you would fill the front/rear as well.
Otherwise, a full set of new innovative mounts is the other sensible option.
If you're dead-set on upgrading the side only, Innovative will sell it to you separately.
shenaniganz08
Los Angeles
with a little searching you would have found the this
http://www.6thgenaccord.com/forums/showthread.php?t=41422
or shop around online.. cause honestly.. no one on here is going to have just that one driver side mount by it self..
oops I didn't clarify that I have a J30 engine
From what i've seen the side mount just sucks PERIOD . It doesn't have enough material for its intended purpose. I replaced all of my motor mounts at the same time about 2-3 years ago and even filled them with polyurethane. The rest of my motor mounts are fine, even the weak looking transmission one still looks brand new.. in other words the side engine mount is the weakest link and I refuse to replace it again.
I went to Innovative's site and they only sell the entire kit, unless theres something I'm missing.
MoneyPit
Abaddon
^Great find. That's a nice price for all three mounts.
But yeah, If you call innovative, they will sell you the side mount separately.
^That.
Not sure if you have OEM mounts now, but if you do and then upgrade to Innovative mounts, you will need longer bolts than what they ship with them.
Hondastylez
Tampa, FL
woo hoo thanks man , still about $80-100 more than what I wanted to pay for just a single mount, but damn good price for all 3
need to check my funds now
No problem.
^That.
Chris, need more info on this. Where did you get the longer bolt ? I just ordered a set.
Thnx bud.
