Led tail lights "Brake Lamp" indicator
Discussion in 'Accord Tech' started by Dnguyen211, Oct 20, 2015.
  1. Dnguyen211
    Dnguyen211 Well-Known Member
    255
    Aug 20, 2015
    Iowa
    I just got LED tail lights and the "Brake Lamp" indicator is on... I don't like it so how can I get rid of it?
  2. RedRyder
    RedRyder Be a better driver
    19,213
    65
    LED's draw less power than your factory bulbs, so you need load resistors to counter that and trick the system.
    Remember to try searching the site before posting, these cars are pretty old so simple things like this have been done/discussed.
  3. Dnguyen211
    255
    Aug 20, 2015
    Iowa
    Led signals
    I have searched but could not find much, I have switchback LEDS for signals in the front and am planning to put some Amber LED signals in the rear, since having resistors for the front signals will I need to wire in some for the rest also?
  4. spacemonkee23
    spacemonkee23 Well-Known Member
    351
    Aug 26, 2014
    Placentia, CA
    My Depo tail lights came with a connector that has one resistor in it so it can read the proper resistance for the brake lamp circuit. It replaces the factory module that was there before.
    Connector w/ resistor. In the trunk, I think it was on the drivers side near the outer tail lamp bolts. The stock version of this connector is a small black box with an open side and visible circuit board.
    [​IMG]
  5. Sino
    Sino Well-Known Member
    120
    Nov 30, 2014
    Massachusetts
    Not sure if it would help with these taillights but when I replaced brake bulbs with LED ones I followed a DIY here that has you pull a wire out of a connector to disable the brake lamp warning. I can look for the thread if anyone's interested.
    Sent from my Nexus 6 using Tapatalk
  6. Dnguyen211
    255
    Aug 20, 2015
    Iowa
    Yes please!
  7. spacemonkee23
    351
    Aug 26, 2014
    Placentia, CA
  8. Sino
    120
    Nov 30, 2014
    Massachusetts
  9. Dnguyen211
    255
    Aug 20, 2015
    Iowa
    It worked!
  10. Dnguyen211
    255
    Aug 20, 2015
    Iowa
    Led signals
    Hi, I have switchback Amber to white led turn signals/markers on the front of my car and now I want to install some White led turn signals and reverse lights in the rear... Since I have load resistors for the bulbs up front will I have to wire in some for the rear too?
Share This Page
