Lowering question?
chaby_91
Montreal
Somebody correct me if I'm wrong... but
1st - Your stock shock absorbers will be able to handle the springs from a month to a year. I heard/seen/read it all.
2nd - As a safety mesure, if I had to get springs installed/removed, I'd get it done professionally
3rd - A camber kit is not necessary, but if you want to get your wheel straight, you will need one
fallout09890
virginia
first off, im going to say get coilovers...620 shipped type 1's and you'll get it in about a week...quick and simple..easier than your springs and shocks.
second all you need is a compressor and set it up CORRECT! if you don't set it up correct that's where the injuries come in. set it up correct and they're as reliable as american cars:jerkit:.
third you don't NEED a camber kit. im dropped about 2-3 inches, not really sure and i have no camber kit. and i already did 110mph on the highway :chucklesfawk:. it's fine but just wears out your tires of course.
but dont the struts in coilovers wear out too?? and if that happens, will the coilovers be rendered useless. Im on a HS student budget so I was planning to stick with OEM struts w/ sportlines till I can save up for coilovers b/c coilovers are $620+$80 for an alignment+ $150-200 on camber kit and I still have tons of stuff that I want to get like a rear sway bar, rims, a retro.... At first I was thinking about those Falken springs on ebay but they sold out of the ones with a 2in drop for the I4 6ga. They only have them for the v6 6ga and from what Ive read on this forum, its not a good idea to put v6 springs on an I4
chaby_91
Montreal
What do you mean by if I want to get my wheel straight? If I skip out on the camber kit, will my steering be affected?
I guess I suck at explaining in english... This will help
Edit : As knighthawk1104 said, it will wear out your tires especially in the inside. By lowering yor car you will get negative camber. This is normal for the rear wheels... it imprives grip when cornering. As for the front wheels, it will reduce your acceleration a tiny bit because the whole tire is not flat on the road
hope this helps
knighthawk1104
New York City
when you lower the car you put stress on so many parts already.
fallout09890
virginia
hope this helps
I get it.. so our cars dont have an OEM camber adjustment which calls for a camber kit
chaby_91
Montreal
Our cars have the cambers needed to handle the stock suspensions. They might be ajustable a bit, but within the range of what the stock suspensions requires.
jdm00accord
kernersville, nc
you can drive fine without a camber kit. i bought a camber kit just to make my camber -2 (more of an angle) cause i like the look. wears the tires but looks so sick. and i always have ppl asking whats wrong with my car and if its broken haha. as for springs, i ran tenzo r springs on stock struts for a good long while with no problems, then i upgraded to megan coilovers on tokico illumina struts when i had the money.
chasnsx
Anaheim, CA
Autozone loans a spring compressor for a $60 credit card deposit, or will sell you one for the same price. You can do the spring/strut job yourself pretty easily, but you will need a shop to align the car after. If you lower the car 2 inches or less, then you will not need a front camber kit (adustable ball joints). However, you will need a rear camber kit. There are three or four out there, but Ingalls Engineering makes the best one because it replaces the two lower arms, giving you full adjustability, instead of just replacing the single upper arm.
Lastly, lowering the car on stock shocks is a bad idea. If they are not already blown, they will be shortly. Spend the money on good shocks that are designed for lowering, like Tokicos, or Konis if you can find them. And if you want more than two inches of drop, then just skip the spring/shock thing and step up to full coilovers.
Chas
