tnguyen600
When my door got stuck... I had removed the top portion of the door panel, just like you have stated...I even cut a hole so that I could stick my hand in there (wouldn't matter since it would be covered). Theres a rocker arm mechanism that you gotta pull so that it releases the door however with my situation, the door was stuck in the lock position. Being that it was stuck in the lock position, there was no use in pulling the rocker arm to release the door...I could've pulled it all day and night and still, the door wouldn't have opened.
I'm not saying that the OP's situation is the same as mine...try removing the top portion of the door panel and manually releasing the door from the inside of the door (make sense? lol) and pray that its not stuck in the locked position.
