My Drivers Door Will Not Unlock!
low430
Portland
If the motor is shot how does it push the lock shaft up and down ?
So on these cars your saying the key hole is not actually connected to the lock?
I got the door panel off, Removed the drivers seat and Im ready for the next step
tnguyen600
Philadelphia, PA
If you cant move the rocker arm to disengage the door, than you gotta just break the lock. My lock was annihilated.
low430
Portland
5 hours of abusing the lock I got it out.
I ended up having to dremel it apart, Ridiculous design.
Next step Order the new lock and install it,
If anyone else is having trouble removing their inner door trim while the door is shut, I had to remove the drivers seat to allow sufficient torque to be applied, Then yanked the bottom pocket out stuck a screwdriver near the rear, Pry while Yanking on the door handle HARD, It will seperate then just lift it off the window rail.
BTW my window is still in tact and I did not have to cut any holes in my interior What so ever.
Thanks to all that helped,
Swollkat
Riverside, CA
Resurrecting this thread because I just dealt with this issue a couple of days ago and didn't want to start a new one. My driver door wouldn't open, but the lock moved up and down. The latch assembly broke.
First, I was able to get my driver's door open without causing major damage. I broke a few clips on the door panel, but it's in one piece and I didn't have to cut a hole in it.
Here's what I did:
1. Removed both seats. You'll need the room to move around
2. Lower the window all the way
3. Unscrew the inside door lock knob
4. Start to pull back the door panel on top from the B pillar side (By door lock knob)
5. Use a long screwdriver or tool to push the top clip out from the inside.
6. Use a little strength to unsnap the door panel from the B pillar side
7. You should be able to angle the door panel up and out
8. There's a tiny plastic plug that will break toward the front and some of the forward clips.
9. Once the door panel is completely off, raise the window
10. Unplug the electrical switches and take a breather
11. Remove the dust cover *if you have one
12. I unscrewed the actuator (3 screws) and plastic cover (1 screw) but after I figured it out you don't need to. It helps to remove and disconnect the rods and actuator so you can see better, but move the inside door handle rod to see how it operates the latch assembly.
13. Take your pick and slide it between the metal slide and white plastic of the latch assembly.
14. Once you hook the latch assembly lever the door should open. See pics
15. There's a rod that connects to the door handle that I just unscrewed inside the door rather that removing the door handle.
This is my contribution to an F'd up problem.
