Need Advice on Timing Belt Replacement!
6thgenbwah
Connecticut
Hey everyone,
I am going to be replacing my timing belt and water pump soon on my 01 v6 coupe. What other (seals, etc...) should I be doing while I have everything apart? Should I replace engine mounts during the process as well? I have 183k currently and the last timing belt and water pump was done about 80k ago.
Thank you
guytv
hill
I was planning on doing the same maintenance. I was just going to buy the timing belt and water pump kit on ebay. Not sure if the kit is good tho, but it does include all the seals.
Also, If you replace the mounts you should replace all the mounts. So, that you could avoid making three new and two old. The old ones will eventually break at some point. You don't want there to be a weak link. I changed my tranny and end up changing all the mounts. My car was 230xxx miles and the mounts had never been changed before. All the mounts were broken. Once I changed the mounts the car felt a lot lighter.:waytogo:
Also, there is a youtube video on this. https://www.youtube.com/watch?v=udYGLoRKU4U
LeoY
NWI
Not sure what they charge on ebay, I just did mine and used this one from amazon, all the parts seemed very high quality. No issues with any of them.https://www.amazon.com/gp/product/B004986ZTO/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
