danmccormick87
1) If you buy aftermarket lowering springs, do they 'bolt on' to the factory struts or is there mod/fab work needed? http://www.amazon.com/gp/aw/d/B007L8...068858&sr=8-6#
They will bolt up with the factory struts, but some people have good luck and they last and others have bad luck and they blow, just depends on who you ask.
2) If I bought these lights, could I used them with hid bulbs and have the same effect as the mh1 retro? http://www.amazon.com/gp/aw/d/B004W4...I1ZI9NM20RXJB3
I have similar headlights on mine, to answer a few of your questions, there is no difference between halogen and HID projectors, a projector is a projector. The difference is the ballast. You can add a HID/LED/Halogen to any projector, with a variation of different light output. IE The 1st generation Hyundai Tiburons came with OE projector headlights that used halogen bulbs, and many people convert the bulb over to HID.
3) Does anyone have a list of all the bulbs needed and how many of each, for a l.e.d. dash/climate control/ everything conversion? I.e. How many t 10, t 5, neowedge, etc...
CLICKY HERE
4) Has anyone added a map light? Mine doesn't have one factory.
Don't mess with adding a map light, just install LED strips similar to what I did. Wire it to your door lights to light up when you open your door and also have it wired with a switch to turn on and off as you see fit
5) Can someone post a picture or link to the factory oil dipstick? Sounds nuts, but if the dipstick I have is stock, I'm running like 3 quarts high. So...
Varnell answered your question above
CLICKY HERE
