A couple of weeks ago I was attempting to make the connection part of the car electrical outlet, a little spark appeared and next thing i know the radio and outlet both stop working. I do some research and replace the fuse, and voila they work. I noticed other fuse's were in not so good condition so I replaced all fuses inside the car, no in engine bay, with new fresh ones. Next thing I know the car slowly starts developing its own little problems, first with no starting, instead my check engine and maintenance light, which have been there for months due to some minor things, are faded and i don't hear the fuel pump priming. Then when they key is turned its just a buzzing clicking sound. I found as a temporary fix to disconnect the battery, then reconnect and it resets the car and lets it turn on and will run fine, or used to. Now If i turn on my high beams, the instrument cluster will black out for a second as well as the radio, even without the high beams the radio now shuts on and off randomly. Someone please help, the problem seems similar to
http://www.6thgenaccord.com/forums/showthread.php?t=50566&highlight=fuse
I'll link some videos of my it in my case
https://youtu.be/x0AS36j-AMU - No Start
https://youtu.be/pLscQbVBGpE - Cluster
