SuperMidget
So I have a 2002 SE sedan 4 cyl, and recently finished converting the car to a standard with a 95 lude 5 speed, changed to OBD 1 from OBD 2b with a Chipped p28, conversion harness, 2 wire IACV swap with plate and installed an additional coolant temp sensor (one wire) for my gauge.
I was really pumped to get the speedo working, and after a few days figured it all out using many guides on these forums (Thanks guys!) and installed my agressive f23 basemap eprom chip... to find that still, the car is slower than it was stock, still no vtec, and no change at all from the stock f23 basemap chip
I also have a vtec indicator light spliced to the ecu vtec output, and it does not light up anymore.
All wires have been soldered and insulated properly... anyone have any input? I've been talking to a few civic tuner dudes, and I have a bunch of knowledge about 'car stuff'
Oh I should note: I gave the programmer of the p28 all the particulars for each chip (that was included in the ecu purchase), from rpm vtec engagement and 2 stage launch control....
I also am not getting 2 stage launch control to work... Anyone know anything about this? I've tried to reach the programmer but he hasn't replied.
(does the ecu need a clutch switch input? My clutch switches aren't hooked up to anything.... also no reverse lights
Cheers Boys!
Cheers Boys!
