what i got so far for all F series motors! have fun!
F18A
This engine was used by Honda.
Bore × Stroke: 85.0 × 81.5 mm
Displacement: 1849 cc
Valve Configuration: SOHC, 16 valves
118 bhp up to 1997
105PS @ 6000 rpm, 14.6 kg m @ 4000 rpm (PGM-carb)
Fuel consumption : 13.0 km/l
[edit] F18B
This engine was used for the Honda Accord 1.8 VTS/VTE in Japan. Also found in the European Honda Accord Vtec S.
Specifications
Valve Configuration: SOHC, 16 valves, VTEC
Compression ratio: 9.3:1
Max power: 138PS (103 kW)
Max torque: 124 ft·lbf (165 N m)
[edit] F20A
This engine series was used in the Honda Accords and Prelude`s in Japan and Europe. The DOHC F20A was also derived from this engine (see below).
Specifications
Bore × Stroke: 87.0 × 88.0 mm
Displacement: 1997 cc
Compression ratio : 9.5:1
Max output : F20A2 110 Ps @ 6000 rpm (PGM-carb)
Max output : F20A4 133 Ps @ 5400 rpm (PGM-Fi)
Max output : F20A5 150 Ps @ 5400 rpm (PGM-Fi)
Max output : F20A7 135 Ps @ 5600 rpm (PGM-Fi)
Max output : F20A8 145 Ps @ 5900 rpm (PGM-Fi)
Max torque : F20A2 16.1 kg m @ 3800 rpm (PGM-carb)
Max torque : F20A4 18.5 kg m @ 4300 rpm (PGM-Fi)
Max torque : F20A7 19.3 kg m @ 4400 rpm (PGM-Fi)
Max torque : F20A8 138ft/lb @ 4400 rpm (PGM-Fi)
Fuel consumption F20A8 Urban - 25 mpg Highway - 34 mpg
Fuel consumption (Japan Combined Cycle) : 9.6 km/l (PGM-Fi), 9.8 km/l (PGM-carb)
This engine also spawned many variants, according to market, but the specs remain largely similar, The F20A5 it's used in the Cb3 and Cb4 Chassis
The F20A7 is only used in the european "Accord Coupé 92-93" CC1 chassis as unique motorisation.
[edit] F20B
The F20B Engine Stream produces 113 kW (154 hp) at 6500 rpm and maximum torque of 186 N•m (137 lb•ft) at 4000 rpm, versus the single-camshaft F20B's 110 kW (148 hp) and 186 N•m (137 lb•ft), respectively. The vehicle's Japanese urban 10/15-mode fuel consumption rating is 14.2 km/L (about 34 mpg)—a 15% improvement over a comparable vehicle powered by the F20B, according to Honda.
Specifications
Configuration Valve: SOHC/DOHC, 16 valves, VTEC/Non-Vtec
This engine came in SOHC in vtec and non vtec, there is also a DOHC VTEC version of the engine, they all share the same engine code although they are very different.
The DOHC VTEC version comes with a blue powder coated valve cover as the H23A VTEC from the japanese accord sir-t. They're called BLUE TOP and are only from japan.
DOHC VTEC Manual Version:
197 HP @ 7200RPM
145 TQ @ 6600RPM
147.10 kw
11.0:1 CR
85mm bore
88mm stroke
23mm wrist pin
145.5mm rods (f20b rod length = 145.425)
1.65 r/s ratio
55mm mains like h22a4 block
rod journal has been offset ground on both sides to the size of a b-series rod journal.
[edit] F20Z
This engine series is similar to the F20A above, used in the Honda Accord in Asia and Europe.
Specifications
Bore × Stroke: 85.0 × 88.0 mm
[edit] F22A
This engine series was used in the Honda Accord and Honda Prelude S. Aside from differences in tuning, these engines are substantially similar.
Specifications
Bore × Stroke: 85.0 × 95.0 mm
Displacement: 2156 cc
Valve Configuration: SOHC, 16 valves, non-VTEC
Compression ratio: 8.8:1
Max power:
F22A1: 125 hp (93.21 4 kW) @ 5200 rpm. NOTE* The 1992-1996 Prelude S had a F22A1 but because of a different more aggressively tuned ECU (P12), the power output was 135 hp (101 kW).
F22A4: 130 hp (96.94 kW) @ 5200 rpm. The F22A4 is the same motor as the F22A1 but it has slightly more power due to a tubular designed header and slightly bigger exhaust piping.
F22A6: 140 hp (104.40 kW) @ 5600 rpm. The F22A6 is the same as the F22A1 except for a slightly more aggressive camshaft, a better flowing cast exhaust manifold, a different more aggressively tuned ECU (PT6), and a different intake manifold that utilizes IAB's and also has a bigger plenum. The F22A6 also has a windage tray in the oil pan, and stiffer valve springs to accommodate the more aggressive camshaft.
F22A7: 140 hp (104.40 kW) @ 5900 rpm (147 hp/108 kW with manual transmission)
Max torque:
F22A1: 137 ft·lbf (186 N m) @ 4000 rpm
F22A4: 142 ft·lbf (193 N m) @ 4000 rpm
F22A6: 142 ft·lbf (193 N m) @ 4500 rpm
F22A7: 145 ft·lbf (198 N m) @ 5000 rpm
[edit] F22B1
This engine was used in the Honda Accord EX and Acura CL 2.2. It was the first F engine to feature VTEC. This engine has a different head than the F22A6 (specifically exhaust manifold/header-pipe as well as intake gasket).
Specifications
Max power: 145 hp (108 kW) @ 5500 rpm
Max torque: 147 ft·lbf (199 N m) @ 4500 rpm
[edit] F22B2
This engine was used in the 1994-1997 Honda Accord DX, LX and SE. The F22B6 in the 1995-1997 Honda Odyssey and the F22B8 in the Honda Shuttle are substantially similar. Also the F22B3 engine used in the 1994-1997 Australian and New Zealand Honda Accord LXi are basically the same engine apart from slightly different intake and exhaust manifolds.
Specifications
Max power: 130 hp (97 kW) @ 5300 rpm
Max torque: 139 ft·lbf (188 N m) @ 4200 rpm
The F22B in the BA9 Prelude had a DOHC configuration
JDM engines were stamped only as F22B.
[edit] F22Z2
This engine was used in the Honda Accord 2.2i.
Specifications
Max power: 150 hp (112 kW) @ 5500 rpm
Max torque: 148 ft·lbf (200 Nm) @ 4500 rpm
[edit] F23A===F23A1
This engine was used in the 1998-2002 Honda Accord LX, EX, and SE, and in the Acura 2.3CL in North America.
Specifications
Bore × Stroke: 86.0 × 97.0 mm
Displacement: 2254 cc
Max power: 150 hp (112 kW) @ 5700 rpm
Max torque: 152 ft·lbf (205 N m) @ 4900 rpm
[edit] F23A4
This engine was used in the 1998-2002 Honda Accord ULEV models. It is substantially similar to the F23A1, but features ULEV certification with a slight reduction of power: 148 hp (108 kW) with a maximum torque of 150 ft·lbf (203 Nm). This engine has a different exhaust manifold and a 32-bit ECU which uses a wideband oxygen sensor.
[edit] F23A5
This engine was used in the 1998-2002 Honda Accord DX and the 2002 Honda Accord LX VP (value package) in North America.
Specifications
Max power: 135 hp (100 kW) @ 5500 rpm
Max torque: 153 ft·lbf (206 Nm) @ 4500 rpm
[edit] F23A7
This engine was substantially similar to the F23A1. It was used in the 1998 Honda Odyssey and the 1998-1999 Isuzu Oasis.
[edit] DOHC engines
[edit] F20A
This engine was used in the 1990–1993 CB3 and CB4 Honda Accord 2.0Si and Si-T in Japan.
Specifications
Valve Configuration: DOHC, 16 valves
Compression ratio: 9.5:1
Max power: 150 hp (112 kW) @ 6100 rpm
Max torque: 137 ft·lbf (186 Nm) @ 5000 rpm
[edit] F20B
This engine series was used in the CF4, CF5, CF9, CL3 Honda Accord and Honda Torneo from Japan. It uses a DOHC VTEC cylinder head similar to the H22A found in the Prelude but was designed to comply with many countries' sub-2.0 liter tax. The automatic transmission versions received the lower hp version (180 hp), as it was tuned for more mid-range torque than its manual transmission counterpart.
Specifications
Accord SiR wagon, SiR-T F20B 97-01 2.0L
Valve train: 4 Cylinder, DOHC VTEC, 16 Valve
Bore: 85.0 mm
Stroke: 88.0 mm
Torque: 145 ft·lbf (197 N·m) @ 5500 rpm
Horsepower: 290 hp (220 kW) @ 7000 rpm
Red Line: 7600 rpm
Compression: 11.0:1
Fuel Control: OBD-2
[edit] F20C
Main article: Honda F20C engine
This engine was a radical departure from previous F engines, and only shared basic dimensions such as bore spacing. It was designed specifically for the Honda S2000 and shares some engineering with the Honda K engine. A long-stroke F22C1 variant was also produced.
[edit] F22B
This engine was used in the 1992–1996 Honda Prelude Si in Japan. It is similar to the H23A.
Specifications
2.2 L
Max power: 166 hp (119 kW) @ 6000 rpm
Max torque: 150 ft·lbf (200 N m) @ 5000 rpm
