Eclipse99fwb
At full lock the pump will whine, that is normal. Glad to hear its nothing more than the pump. Check your power steering belt to see if it needs replacing with the pump.
This is because the rack is at full lock and doesn't need more fluid to pass thru it. Once you come off full lock, the fluid starts rushing thru the system, and bringing the air with it.I didn't say it was whining at full lock. I said that the pump seemed starved for PS fluid. As in, there was no PS fluid reaching the pump when it was at lock.
Everytime my wife would go to lock, no fluid came into the PS reservoir and when it left the lock, fluid would come gushing in and there would be air bubbles mixed in.
Separately, is there any reason why to use Honda brand PS fluid over any other company? Like, for example when people use Honda brand coolant, it's because they say "it's 'Honda' brand, so use it", but they don't know why. The REASON why people use it over other brand coolants is because it's silicate free. Prestone concentrate and their 50/50 mix is silicate free coolant, so I'm OK using it. Coming off of that, is why I ask if there's a reason why to use Honda brand PS fluid? Does Honda brand PS fluid have something or not have something that other brand PS fluids have or don't have that is needed / not needed in Honda brand PS fluid?
The Honda PS fluid seems to keep the pump quieter, and it might have some extra stuff in it that keeps the hoses and "O" rings lubed.
As for using Prestone anti-freeze, I wouldn't. Prestone has changed it's formula to that of GM's Dexcool, which is the absolute worst stuff you can run in an engine. Even the GM guys are getting rid of it, as it clogs heater cores and engine blocks. It forms a crystal like substance, and just keeps getting worse the longer it's in place. I don't know about the blue Honda stuff, but it wouldn't surprise if it did it too. I've been using Peak in everything for the last 10 years or so without any problems in my GM's, and 4 years now in my Hondas.
