Power Window Switches Different?
Discussion in 'Car Audio & Electronics' started by _Kodiak_, Apr 8, 2022.
  1. _Kodiak_
    _Kodiak_ Member
    28
    8
    Jan 19, 2021
    Chico, CA
    Hi, everyone. Just been out at the parts yard today and pulled the wood grain switch panels with switches out of either a '99 or '00 Accord to replace my basic gray ones. When I installed them all and turned the key on to test, all the window switches except the driver side were making a buzzing sound, goes away if I turn the key or master window switch on the driver side panel off. Not the motors, the switches themselves. I'm thinking it's a slight difference in wiring like pin locations on the switches? Swapped the original switches back in and everything is fine.
  2. Marc Garvey
    Marc Garvey Member
    Jun 2, 2021
    So cal
    Yes. Replaced a door and had to repin the harness. Easy to do. You tube. Swapped some colors to the correct location and it worked fine.
  3. FNCONE
    FNCONE Well-Known Member
    364
    14
    Feb 8, 2013
    NYC
    Or Use your old switches, if u didn't throw them out.
    Becareful , I damaged the door master switch (which is a multiplexor) when I did this mistake.
    if u threw them out then u need to re-pin
    Switches Pin 01-02 98-00
    Passenger
    1 Blu/Yel Same
    2 Blu/Yel Pin 6
    3 Blu Pin 5
    4 WHT/RED Pin 2
    5 Blu/Blk Pin 3
    6 Blu/WHT Pin 4
    Passenger Rear
    1 YEL Pin 6
    2 Red/YEL Pin 1
    3 Yel/Grn Pin 5
    4 WHT/RED Pin 2
    5 Wht/BLK Pin 3
    6 Red/BLU pin 4
    Driver Rear
    1 GRN/BLU Pin 6
    2 RED/YEL Pin 1
    3 GRN Pin 5
    4 WHT/RED Pin 2
    5 WHT/YEL Pin 3
    6 RED/BLU Pin 4
    cg4ever and RedRyder like this.
  4. RedRyder
    RedRyder Save the manuals
    19,471
    108
    ^This guy is the freakin wiring MASTER! He knows his stuff.
    FNCONE and cg4ever like this.
  5. cg4ever
    cg4ever Well-Known Member
    168
    19
    Sep 5, 2018
    Europe
    Btw hi RedRyder and FNCONE !
    Not only that, he's a very helpful and trustworthy person. He helped me getting a part from US to overseas that i badly wanted and which was initially not shippable overseas. He's the man !
    FNCONE and RedRyder like this.
Share This Page
