Rear brake plates of 282 mm - Installation of set of rear naves with Inspire UA5 type S.
Discussion in 'Suspension, Brakes, Wheels, and Tires' started by SergA73, May 21, 2019.
  1. SergA73
    SergA73 Member
    24
    May 16, 2019
    Russia , Taganrog
    I welcome all reading!
    Periodically there were problems with rear calipers, especially with left, but served always both.
    Long ago wished to improve the rear braking system and to pass to brake plates 282 mm (the original on coupe of 262 mm) therefore the set of rear naves from Honda Inspire UA5 type S with bench hammer ropes has been ordered from the broken car (native ropes of the bench hammer do not approach).
    [​IMG]
    here they are handsome)
    Before arrival on HUNDRED on replacement, itself has disassembled the central extension housing that there was access to resetting and fixture of ropes of the bench hammer in interior.
    [​IMG]
    look after removal of the central extension housing, between seats fixture of ropes of the bench hammer and resetting
    The right side has been made the first, everything became and, exception only bench hammer cable length, on Honda Inspire UA5 typeS it is longer. On the regular place of fixture of cable on the longitudinal lever to fix it has not turned out as the cable corner to nave turns out not direct, the option has been chosen as such, as on photo:
    [​IMG]
    It is visible as has passed bench hammer rope. That the cable has not frayed about metal on it the piece of oxygen hose has been dressed and insulated by insulating tape in color of body). Further fixture of cable as at coupe, original from Honda Accord, the 6thgen.
    Have passed to sort the left side …
    [​IMG]
    Brakes became sharp, the bench hammer perfectly well (better than was).
    Generally I recommend such replacement!
    Maybe information from what car is required this set of the braking system suits us on coupe without alterations:
    HONDA Inspire III 3.2 Type S
    VIN: UA5-1301104
    Year of manufacture: 2002
    Engine: J32A
    I transport through Google the translator if that ask.
    All of success in everything and excellent VTECa!
  2. Nam1911a1
    Nam1911a1 Well-Known Member
    688
    14
    Aug 16, 2016
    Southern Indiana
    Awesome man!! It is great that it worked out well for you. I never converted my Accord to rear disc brakes. It stopped great for me with the rear drums and upgraded front brake pads
  3. SykVSyx
    SykVSyx Well-Known Member
    13,933
    25
    Jan 6, 2007
    Tee Dot Ohh
    Nice upgrade. This write up should be helpful for future.
  4. SergA73
    SergA73 Member
    24
    May 16, 2019
    Russia , Taganrog
    [QUOTE = "SykVSyx, сообщение: 1114656, участник: 635"] Отличное обновление. Эта статья должна быть полезной для будущего. [/ QUOTE]
    Очень рекомендую такую замену!
    После такой замены у нас за колодкой стояночного тормоза - барабан и колодки для тормозных дисков, это на много проще, чем у нашего семейства суппортов.
  5. SergA73
    SergA73 Member
    24
    May 16, 2019
    Russia , Taganrog
    [QUOTE = "Nam1911a1, должность: 1114633, участник: 19956»] Awesome man !! Здорово, что это хорошо сработало для тебя. Я никогда не конвертировал свой Аккорд в задние дисковые тормоза. Это остановилось отлично для меня с задними барабанами и модернизированными передними тормозными колодками [/ QUOTE]
    Любимый автомобиль нужно улучшать всегда, если есть такая возможность!
Share This Page
