reprogramed alarm remote?
jdmcg3
Seattle, Washington
Was out in a junk yard and came across the unlock/lock/etc remote key and since I lost mine I picked it up hoping it could be reprogramed for my car.. is this possible and how?
20-CG5-01
KanomNom
Kodiak Alaska
Check the back of the remote and what's the vin numbers. Then Google that number up to see if it is compatible with your car. LX is different from the EX.
And to program it just Google. There's a video on YouTube but they did it on a crv but it should be the same.
dharding413
Keep it simple.
Charlottesville, VA
This was posted awhile ago, but I'm pretty sure its the steps I used when programming mine. Hope it helps.
i think if you have a 91-00 you can do this :
Storing transmitter codes:
The codes of up to three transmitters can be read into the keyless receiver unit memory. (If a fourth code is stored, the code which was input first will be erased.)
NOTE: It is important to maintain the time limits between the steps.
Turn the ignition switch ON (II).
Within 1 to 4 sec. , push the transmitter lock or unlock button with the transmitter aimed at the receive (control unit).
Within 1 to 4 sec. , turn the ignition switch OFF .
Within 1 to 4 sec. , turn the ignition switch ON (II).
Within 1 to 4 sec. , push the transmitter lock or unlock button with the transmitter aimed at the receiver (control unit).
Within 4 sec. , turn the ignition switch ON (II).
Confirm you can hear the sound of the door lock actuators. Within 1 to 4 sec. , push the transmitter lock or unlock button again.
Within 15 sec. , aim the transmitters (up to three) whose codes you want to store at the receiver, and press the transmitter lock or unlock buttons. Confirm that you can hear the sound of the door lock actuators after each transmitter code is stored.
Turn the ignition switch OFF , and pull out the key.
Confirm proper operation with the new codes(s).
hope this helps.
