Sluggish Engine
Discussion in 'Accord Tech' started by 99F23VTech, Sep 1, 2009.
  1. 99F23VTech
    99F23VTech Well-Known Member
    263
    Jul 3, 2007
    Washington State/Tennesse
    I am having some serious issues with my car. Awhile back i got a CEL for the 02 sensor/cat. I heard some rattle in the cat haven't been able to pull it off yet, car ran okay even with the CEL.. Well a few weeks down the line my car is nearly gutless...
    I am unable to rev past 3k rpm's even without a load. With a load i am able to get up to 40mph in 5th gear but wont go any further in 1st 2nd or 3rd i can barely reach 25 mph. If i try to rev past 3k rpms the engine shakes and once i let it down to idle it will die...
    Possible problem:
    Cats Plugged
    (not sure of anything else)
    If anyone could shed some light on the situation i really need it. If you have had a similar problem and you were able to fix it that would be great.
    Thanks
  2. BlkCurrantKord
    9,289
    41
    Sep 7, 2005
    Cat clogged..
  3. 99F23VTech
    263
    Jul 3, 2007
    So you think for sure its the cat? I am going to try to pound all the honey comb crap out and see if that does a thing. (No emissions where i come from)
  4. BlkCurrantKord
    9,289
    41
    Sep 7, 2005
    Sounds like it
  5. Sketch o5
    Sketch o5 Señor Greengo
    22,491
    55
    Sep 6, 2005
    yea, its probably the cat being clogged. ever since i got my new cat a couple weeks ago, i definitely noticed that the car runs better than it did.
  6. 99F23VTech
    263
    Jul 3, 2007
    Thanks for the replys... Where did you get your cat sketch?
  7. jwong512
    jwong512 Well-Known Member
    1,287
    Aug 22, 2009
    Socal 626
    Usually when the cat is clogged, how would you go about cleaning it? Would Seafoaming your car clean it?
  8. HondaLuver83
    HondaLuver83 Well-Known Member
    35
    5,000
    24
    Oct 22, 2008
    No, because there are actually metal peices in the cat that are broken up. It looks like a honey comb in the cat. If I was the OP, I would just gut it out and buy an O2 fouler for $40. It gives u little more power and no CEL. Pluss its much cheaper than buying another cat.
    But dont tell al gore about this.
  9. jwong512
    1,287
    Aug 22, 2009
    Socal 626
    OH! How does that usually happen?
  10. Sketch o5
    22,491
    55
    Sep 6, 2005
    the fouler trick wont make his cat unclogged. thus, his car will still run like dick and hell be out $40.
    i got my cat from napa. its nothing great, but it was cheap and immediately available.
Share This Page
