Steering wheel shaking
Discussion in 'Suspension, Brakes, Wheels, and Tires' started by barfo, Jun 27, 2018.
  1. barfo
    barfo Member
    23
    Aug 13, 2014
    1998 Accord EX 5-speed sedan...I have new tires, alignment check was good, and just had front brakes and rotors replaced. When I drive on the interstate and quickly depress and release the brake pedal, my steering wheel begins to shake. Once I get off the interstate and make a complete stop and then jump back on the interstate, it doesn’t shake anymore until I quickly depress and release the pedal again. Could this be the caliper piston(s) are sticking or have something to do with the brake master cylinder?
    Thanks!
  2. Nam1911a1
    Nam1911a1 Well-Known Member
    427
    Aug 16, 2016
    Southern Indiana
    So it doesn't shake when you are braking only when you let off the brakes?
  3. barfo
    barfo Member
    23
    Aug 13, 2014
    Correct. It doesn’t seem to do it when I gradually depress and release the pedal, only after I’ve quickly depressed and release the pedal when I’m cruising at higher speeds.
  4. barfo
    barfo Member
    23
    Aug 13, 2014
    I’m wondering if it could be the power steering pump.
  5. DarkSideAccord
    DarkSideAccord nadeshiko fobz ftw..
    37
    17,664
    22
    Sep 19, 2005
    did u tighten the caliper bracket and lug nuts correctly....?
Share This Page
