Swapping Heads
jdmcg5f23a1
texas
@greekpizza
i see ur f23 is turbo with well over 200 hp and tq how much work did u do to achieve those numbers? i mean if ur running 6.5 psi u must have stock internals? cuz if u had forged internals im sure u would run atleast 10 psi? and woud produce close to 400 hp? can u dm a lil bit about ur build?
based in: not shared
@greekpizza
there's a link in his signature that says 'F23 Turbo Build'.
Keep the head, imo. Less weight ;)
You could get another F23 head and work on it, like a mild P&P, maybe a cam, maybe deck it to raise compression.
Or build a junkyard turbo. Used turbo/IC/injectors, from anything. I have done this for ~$250, and doubled stock HP.
