V6 B7XA Transmission Issue
BeardedWunder
Keizer, OR
Hey guys recently bought a 2000 Accord LX V6 for my sons first car. Its a cream puff, 1 owner, garage kept 160,000 miles. I'm having a weird tranny issue though. trans shifts beautifully, but when I'm coming to a stop it doesn't seem to shift back down to 1st gear on its own. If i put it in neutral and back to drive its fine. If i leave it in drive and just take off it seems to start in either 2nd or 3rd then down shifts fairly quickly and off we go.
anyone have any ideas on what would be causing this?
I'm hoping its an easy fix. we only paid 1500 bucks for it, and have every service record for it from day 1.
I applaud you in your choice of an old Honda for your kid's first car. And not only because this is a 6GA enthusiast forum hah, but also because I see so many parents buying their kids really nice first cars nowadays, which as a parent I personally disagree with.
Anyway, my first thought is change the trans fluid with OEM Honda DW-1. If still persisting, try cleaning the shift solenoids.
ricko
Edmonton
change it, drive it 100 miles, change it again, 100 miles then one more time. My 2000 LX V6 has developed a shifting issue and I have replaced all solenoids, and the speed sensor. Just about to put it back together. 350k miles, LOVE this car so I am determined to resolve it.
Latinbid
Orlando
I have the same issue with my 300000 mile 2001 in January, 2025. I remove the battery and then the double solenoid from the top of the transmission.
There are three little metal tubes sticking out on the granny. I pull them out and carefully removed the little tiny screens inside the tubes and cleaned them. They were dirty. Put everything back and a year later is doing the samething again. But it lasted 10 month working fine. I have not changed solenoid yet.
BeardedWunder
Keizer, OR
alright this issues gets stranger.
I replaced the shift linear solenoid and the lockup/shift solenoid, replaced the inline filter and drained/filled the fluid with genuine honda DW-1 fluid.
now the car doesnt want to shift out of first and when it does it shifts super hard at a super high RPM. I am also getting a check engine light and the D4 light flashing.
not sure how it got worse with replacing parts. any ideas??
Pull the code.
It's likely it needed a transmission replacement the whole time, the new solenoids and fluid are just making it more apparent.
Latinbid
Orlando
My transmission was failing to change to 1st gear on the 1st 15 minutes of operation (and 30 during winter). I could only start on 2nd gear and then drive. I purchased some generic solenoid kit for a few dollars and the car will not moved. I clean the three microscreens from the largest solenoid and clean the larger screen on the shift solenoid (underneath a bunch of cables) and is being running like new for a year. I change the trans fluid every six month. The generic solenoids do not worked for me. The OEM are the ones that work. In my case I still have the originals with 290000 miles.
