Window problem
Drew707
Bay area, CA
My driver window came of the track so its like falling out. What glue do i need to use to stick it back on there?
kn0x47
Senior Member
Birmingham, AL
none. take the door panel off and retighten the bolts that hold the window to the rail
coops-sedan
There's a sort of clamp that holds the window inside of the door skin. I can't remember the exact glue I used but once I fixed it. I never had an issue again.
Drew707
Bay area, CA
Interesting i dnt remember there being any bolts on the clamps the last time this happened. Il be sure to check that out.
Drew707
Bay area, CA
Took the panel off all is see is this one bilt that hold the window up. No bolts that actually tighten the window down. The window wasnt off the track. But wen i raise the window up its crooked im guessing the regulator is off or something. I replaced the regulator months ago maybe i need to buy a new one
