Yes it is. The door posts are lettered in order from the front. The A pillar holds the front windscreen, The B pillar is the post between the 2 doors The C pillar is at the back - usually much wider.
The glass has a pretty good curve to it, so if the track that it runs in gets dented or misaligned, it will be hard for the motor to push it thru the guide. There are 2 guides for the glass. The front one is hidden within the door and the back one you can see the top half of it surrounding the glass at the back.
I just posted a DIY (in the DIY section) for replacing the right front regulator, which shows you how to get into the door. You may be lucky and find the tight spot and open it up a bit or re align it. Actually I just looked on line and the channel parts are very cheap $12-$15. May be better of just replacing those. (find 30 & 31)
http://www.showcasehondaparts.com/p...a4at/body-air-conditioning/front-door-windows
