Hi all,
I'm (obviously) new, but I've been reading here for sometime as I try to fix my 2000 Accord Coupe. I know this topic has been discussed before, but I've not been successful with any advice thus given. So here goes...
My problem: both left and right brake lights are out. The center (window) brake light works just fine. Every function of the tail lights work (signals, running lights, etc) except the brake lights. The do not light up under any circumstance.
My first Macgyver: I hot wired both left and right brake lights to the center brake light. (I cut the power supply wire from the side lights (black/white) and spliced them to the center light. It worked just fine, but is only meant to be temporary.
What I've tried with no success:
-I replaced the wiring harness for both tail lights in case of a bad socket and to fix my temporary solution.
-I replaced the Brake Light Failure Sensor (as others have suggested)
-I checked all fuses & relays
-I checked all grounds
-I checked all wires for shorts/breaks
-I replaced bulbs (as mentioned above)
Here is what's odd: I used a multimeter to do some investigation. I can detect 12v of power going into the Brake Light Failure Sensor. But there is no power coming out. I am not ready to believe that my new-from-the-dealer sensor is bad. Here's why: If it jump the Black/White power-in to the Green power-out, I cannot get any reading at all from the Black/White wire.
I am at a complete loss here. I feel like my car is defying the laws of the physical universe! I know some of this is probably not clear, and I will answer any questions as soon as possible. Thank you in advance for any answers and for even reading this diatribe.
