hondaluver
I had this intermittent problem as well.
Thoroughly cleaned the intake manifold, iacv, fitv, installed new seals where needed. Changed coil inside distributor, the main relay, ignition switch. Changed the ignition module inside the distributor.... Finally! problem gone . Fuel pump was the last resort since they rarely go out.
Would the ignition module cause the gauges to die also and the key light to flash ?? It happens for only a second and resumes normal. I am still leaning towards the ignition switch currently.
