You can certainly duct-tape some of the air ducts. (I'm assuming that you're asking w/o having the motor fixed.)
・ You can manually close the vent for diriver & passenger air vent. (those dials. from ◎ to 〇)
・ You can duct-tape those vents by the clock. (You need to remove the trim bazel to access them.) Here is the DIY thread for that → http://www.filtsai.com/accord/stereo/index.php (Follow the first 3 steps.)
・ You can duct-tape those vents under your seats. (By sliding your seats all the way up front.)
・ You can duct-tape the vent by the windshield.
・ (Maybe this one is the most effective one.) → Duct-taping the vent outside. It is located at the bottom of the windshield, by the driver's side wiper blade.
thanx,,but i need to use the AC as well,,its hella hot here,,and with the recirulation motor malfunctiong,,i cannt stop the fresh air coming into the car,,the air is very warm here,,,,
yes,,exactly, i took the recirculation motor out,and moved the Shutter back , the air stopped coming into the car,,i put super glue with a screw in the bracket of the Shutter which moves with the hook on the recirculation motor now air doesnt come into the car which was blowing earlier, but i feel HOT AIR coming out from the AC vents,, Shud i check the AIR CONTROL VALVE on the firewall? need advise please
Are u sure ur knobs aren't broken? And not the air control valve? Pull the knobs off n check if their broken b4 u start tearing in to the car some more
it must be broken,,caz it moves round way too easily,,u dont need to apply more force,,,but i willl go right now and will close the air control valve manually on the fire wall
