Advice needed for transmission maintenance
Some flush has a metal 'ball' with a diaphragm in the middle, some are a long tube with a free-floating piston in the middle. There may be others.
Most are setup so you put NEW atf in the top. then you have 2 lines,
open trans cooler line, now you have 2
new line to cooler
old line 'from' trans
start. run/rev till full.
disconnect/reconnect
now you have 'tube' filled with old fluid! and a clean car!!
Warning:
Expect MIL for cars that compare TO & FROM pressure, like Honda
Use ~12qt on ~3qt D&F, 9qt total to make up for lost fluid
When your manual says do a D&F every 15kMi, can you do the whole thing at 45k? Or 60k?
I don't f'kin know. I do D&F at ~10k, so this balances out. Takes less time than a LOF.
Get ATF and drain plug sealing washer (!!!!!) at Honda.
briansan
Havertown, PA
xci,
it's quite clear that you are the guru in this forum so i was wondering if you could explain some of the jargon you just used? i understood some of them like
d&f => drain and flush
atf => auto trans fluid
but some are completely beyond me...
mil?
lof?
Also, i don't understand this line:
MIL = malfunction indicator light
same as
CEL = check engine light
LOF = normal jargon, for Lube Oil Filter
Ball:
Tube:
CAN'T FIND!!!! :( it was cool too, used it on Honda's
Other:
I personally have one I made out of a house weed-sprayer goohicky for using on Suzuki (cars, RIP) :)
Yup.
Get one of these, and I'll tell you how.
(I will, but it is useless on the Accord, works great on actual Suzuki's--F'k the Forenza)
No, the tube was sweet, like 6' long 6" diam CLEAR tube, with a piston instead of diaphragm. So you could see what went in/out!
Chezik-Bell Honda (was HWY1 Iowa City) had one, if anyone works there and can grab a pic...
That was my homemade one, out of a grass-weed thing (well, that not my diy)
