You DO NOT need to use Honda coolant. Prestone/Peak coolant bottle for all vehicles will work just fine. You can buy premixed or concentrated and mix it 50/50 yourself with tap water or deionized water(recommended)
The correct way to bleed the coolant would be to
-Open radiator cap on cold engine
-Top overflow bottle to just slightly below the max line.
-Use a 10mm socket and open the bleeder screw
-Use a funnel and add coolant to the radiator until you see a steady stream of coolant coming out of the bleeder screw. Once so tighten the bleeder screw down(without breaking it)
-Start the car with the radiator cap off and allow it to run until the radiator fans come on once or about 5-10minutes to allow all air to escape the system. If the level gets close to the bottom of the rad neck TOP IT UP (do not worry if the coolant starts overflowing a tiny bit). If you are worried about it overflowing and making a bit of a mess then you can take a funnel and use electrical tape on its tip to extend it so it will fit snuggly on the radiator head.
-Put the radiator cap back on and wait for the rad fans to come on if they didn't already.
-If the radiator fans do not come on you've got an issue with either the fans or the fan switch.
Ok i did all that but my fans didn't come on even after I put the cap on they did however come on when i turned the A/C on
